System Speed Booster 2.9.0.6
INFO
Download FileSonic
INFO
System Speed Booster 2.9.0.6 | 3.9 MB
Scan and clean invalid registry entries to keep your PC at the peak performance! System Speed booster offers quantity of functions to scan your registry and return the result with corrupt, harmful registry entries, files and problems, which you can fix by a click of the Cure button on the neat and easy-to-use interface. With many bells and whistles offered by System Speed Booster, you can enjoy more fascinating features just with this FREE and space-saved application installed on your computer.
System Speed Booster is extremely easy to install and to operate. There is no requirement for any register or any identity information of users. The navigation gives you a clear way to master all its features, including the scanning, curing, and other utilities. As an advanced registry cleaner, System Speed Booster can perfectly cope with the registry clean, Privacy sweep, junk files removal and system optimization at a time. Specifically, System Speed Booster focuses on the scanning of the junked registry entries, individual online histories, obsolete harmful files, and removing of hard drive trashes, repairing of system errors. In this way, System Speed Booster is capable to optimize your computer and keep it at the Peak Performance, as well as to protect your personal information.
In addition, System Speed Booster gives plenty of free charming utilities, such as Disk Cleaner, System Information, Auto ShutDown, etc., with which you can learn the technical information of your computer and control the settings and enjoy other easy and convenient
Highlights of System Speed Booster
# Streamline Registry
By scanning and removing all the obsolete registry entries, System Speed Booster will make your Windows registry compact and clean to speed up the running of your PC.
# Optimize System
Problems will be found in your system, with the help of System Speed Booster you can fix all the errors for an optimization of system.
# Faster Work Efficiency
From installing to running the app, the processes are smooth and fast. Just a few minutes, you will enjoy the best PC experience ever.
# Multi-functional
Besides the Registry Fix functions, other built-in tools include Privacy Sweep, Junk Files Removal, System Optimization, etc. All these tasks can be settled in one go.
Homepage -http://www.systemspeedbooster.com/
Download FileSonic
代碼:
http://www.filesonic.com/file/S9lnzUd/
