Sossaman: Yonah DP相關訊息!
sxs112.tw
After the very large success of our article on Pentium M, we could obtain other information of our preferred Russian sources. Those thus could obtain a document of presentation of INTEL on the futures processors planned for 2006. In those, here is one which leaves the batch clearly, as you can see it on slide Ci below. Currently known under the name of code of "Sossaman", this processor is in fact located in the series waiter. Derived from Yonah (Dothan Bi-Core), Sossaman will be in fact the first processor of the range Pentium M to support operation in SMP. One will be able thus to thus make function two Sossaman, them-even Bi-core on a mother chart waiter. Of what seriously to go on the plat bands of Xeon.
Level specifications, slide teaches us that Sossaman will be equipped with 2 Mo of mask L2 (1 Mo by processor) and that the frequency envisaged of introduction will be 2.3 GHz. It will also support the EM64T ("36 bit memory addressing"), the EIST (Gayserville 3), multi-threading (CPU Bi-Core obliges) and the "FSB address and dated parity", a system of control of errors on the data bus. One also learn that it will be equipped with a FSB667, that is to say 166 real MHz with a process of improvement of the bond SMPs. Niveau dissipation, Sossaman will support 100°C and will not consume more than 31 Watts. A version LV (Low Voltage) with 16w will be also available, which will make it possible to make passive cooling. Sossaman will be always on Socket µFCPGA, but with a pinout different from other CPUs (like Dothan compared to Pentium 4). Level availability, although envisaged for Q1' 06, Sossaman would be already in the course of validation, therefore, like Yonah, already tapped-out...
相關來源
計畫給server用的...
架構還算不錯(有夢最美 :PPP: )
但是很好奇那個36-bit memory addressing :??:
確定是EM64T的??
不是做parity check的??
Originally posted by tacoChang@Nov 10 2004, 04:57 PM
計畫給server用的...
架構還算不錯(有夢最美 :PPP: )
確定是EM64T的??
不是做parity check的??
PAE 也是36bit addressing
Originally posted by forum+Nov 10 2004, 05:38 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (forum @ Nov 10 2004, 05:38 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-tacoChang@Nov 10 2004, 04:57 PM
計畫給server用的...
架構還算不錯(有夢最美 :PPP: )
確定是EM64T的??
不是做parity check的??
PAE 也是36bit addressing [/b][/quote]
sorry...誤解了... l|||
查了一下
Intel從Pentium Pro開始就是36bit
看來這只是Xeon系列一貫的配置
應該不是EM64T...
:( 所以其實不會有EM64T了?
FSB只有667...Orz
現在不是都1066了嗎...?
Originally posted by windaz@Nov 10 2004, 06:19 PM
FSB只有667...Orz
現在不是都1066了嗎...?
Pentium M架構又不像P-4系列
需要大量的資料來填充管線
所以667是很夠的...
其實我比較希望它跑800配雙通道DDR :MMM:
