SolidWorks Enterprise PDM 2012 x32&x64 (RAR@1.11GB@多空間)
yohoman0000
【檔案名稱】:SolidWorks Enterprise PDM 2012 SP0.0 WiN32&WiN64
【軟體語言】:多國語言
【軟體類型】:美工繪圖
【檔案格式】:RAR
【檔案大小】:1.11B
【壓縮密碼】:無
【上傳空間】:Filepost/Wupload/Crocko/Filesonic/FreakShare
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
[font=標楷體]Enterprise PDM是Solidworks公司推出的一個具有整套數據管理功能的解決方案,適合任何規模的組織。
SolidWorks Enterprise PDM是世界上唯一一個與Windows資源管理器無縫集成的PDM軟件。 SolidWorks Enterprise PDM 的部署時間僅為其他企業級PDM 系統所需時間的幾分之一。它可以幫助使用企業更有效地管理和共享產品數據,從而在更短的時間內創造更好的產品。
SolidWorks Enterprise PDM 2012 - a software solution for safe storage, management and access to project data, allowing you to create new products faster and with better quality. It is specially optimized for companies with geographically extensive network of offices, subcontractors and suppliers. Management of DBMS technology is based on Microsoft SQL Server. Being fully integrated with Microsoft Windows Explorer, SolidWorks Enterprise PDM system in 2012 can be implemented in the workplace in a very short time with minimum staff training.
eobhodimaya effective product information delivered at the right time to get the cost of production to meet the needs of your customers. SolidWorks Enterprise PDM enables members of your organization work effectively together, to more quickly to market quality products.
Increase the efficiency of data management with best-in-class system
Improving the product development process by providing direct access to the most current versions of all documents and data using the integrated interface with Windows Explorer. Effective data management enables engineers, manufacturing, and marketing service to avoid mistakes, such as those dealing with the wrong versions of documents or accidentally overwrite a version of the document. In addition, SolidWorks Enterprise PDM enables intelligent database, re-use, maintain and enhance. Using a powerful, yet easy to use tool, designers can quickly find the products your documents and avoid unnecessary data.
SolidWorks Enterprise PDM capabilities are well proven in various
industries, including machinery, electronics and medicine.
SolidWorks Enterprise PDM simplifies product changes and information sharing, as well as providing access to the Internet and the ability to integrate
with other systems in the enterprise, such as MRP / ERP, using industry-standard XML and other features.
Rapid implementation and scalability
With SolidWorks Enterprise PDM, you can implement effective solutions to the PDM
much faster than other solutions in its class. Start with a small working group
and increase productivity, and then scale your solution, including hundreds of users from different locations. With the support of any files Microsoft ® Windows, your organization can more effectively manage and share all kinds of information and product data from engineering documents and specifications to the marketing order. To improve data management and workflow, in structural duplication of jobs, SolidWorks Enterprise PDM
allows the integration of widely dispersed corporate divisions, departments, customers and suppliers. With automatic replication of data to the set of placements, users can reduce the critical time when downloading large assemblies.
Streamline processes with workflow automation.
Built-slotting in SolidWorks Enterprise PDM can help your organization to automate approval processes for documents and reduce the number of errors while improving efficiency. For example, many operations can be executed automatically at a standard release a new version of the product, such as automatic control, data entry stamp in the drawing, a neutral file format and issue various notices, such as projects management and sales.
Dual electronic signature is supported by the certificate of FDA CFR Part 11 and other industry requirements.
Audit work to improve standards compliance and quality
SolidWorks Enterprise PDM tracks and records every event, every movement of the instrument and each version. Instrument audit records - who did what and when, how and why each change was made, simplifies the preparation of reports to internal quality as a necessary requirement of the supervisory bodies and ISO auditors. Auditing activities more effectively and earlier can help to identify potential problems and continuously improve processes, increasing the ability to compete for your organization.
Sharing information with your customers and suppliers
With SolidWorks Enterprise PDM you can extend the benefits of data management and workflow, enhance the engagement of customers and suppliers. SolidWorks
Enterprise PDM can provide the right level of access to information for each member of your team, increasing efficiency without compromising confidentiality or security. Dissemination of information about the product to customers and suppliers with SolidWorks Enterprise PDM shortens the product development process.
Platform: Windows XP / Vista / 7 / Server 2003/2008/2008R2 x32 + x64
Compatibility with Vista: complete
Compatible with Win7: complete
System requirements: Server - A computer with Microsoft SQL Server (Express or full) 2005 SP1 or higher for the client - configuration for SolidWorks 2012.
請詳閱 SolidWorks Enterprise PDM 2012安裝操作指南說明!!
Chinese Simp. 簡中
Chinese Trad. 繁中
SolidWorks Enterprise PDM 2012 What's New 新增功能
Chinese Simp. 簡中
Chinese Trad. 繁中
[/font]
下載地址: (等待5秒再按下右上的Skip AD就可到下載頁)
Filepost載點Part1
Filepost載點Part2
Wupload載點Part1
Wupload載點Part2
Easy Share載點Part1
Easy Share載點Part2
Filesonic載點Part1
Filesonic載點Part2
Freakshare載點Part1
Freakshare載點Part2
下載技巧:
可用JDownloader下載
JDownloader載點 || JDownloader後備載點
各空間等待時間為10至30分鐘,本身是該空間之Premium用戶則無以上問題
請勿使用續傳軟體抓取(如迅雷、Flashget等等),以免抓取失敗或抓到不完整檔案
[更新]WinRAR 4.0.1 Pro 32bit&64bit
4.0.1載點 || 4.0.1後備載點
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
1.僅供網路測試無任何販售行為及獲得任何利益!請於測試完後24小時以內將檔案刪除!
2.請支持正版!本檔案的提供純為試看用途,請勿作商業上之用途!!!!請於下載完後24小時以內將檔案刪除!!!
