Site Studio 6.0 Pro
  • 主題發起人 主題發起人 viet80
viet80
Site Studio 6.0 Pro
代碼:
Info:
With Site Studio Pro you can create just about any website possible!
You have the choice of creating a website from scratch or you can use one of the many professionally designed concept templates especially suited for companies and organizations.
Site Studio Pro is completely based on modern technology and equipped with the full support to optimize your website for search engines.
Site Studio Pro makes you visible on the Internet!
With Site Studio Pro you can easily edit your website and keep it up to date - As easy as using any word processing tool.
Site Studio Pro also offers a one-click solution for publishing (FTP) the website to the Internet.
If you are familiar with ordinary word processing tools, then you can easily create websites with Site Studio Pro.
Visual editing
Site Studio's visual editor shows you how the final page looks like while editing, i.e. WYSIWYG (What You See Is What You Get) editing.
WYSIWYG editing (What You See Is What You Get) is used to edit and create websites. It's just as easy as word processing tools.
Modern Standards - XHTML and CSS
Site Studio generates web pages which conform to the XHTML 1.0 strict standard.
XHTML is the successor to HTML since 2000. XHTML is based on XML and describes the content instead of describing how it should be shown.
Since XHTML is based on XML, the syntax for XHTML is the same as is used for XML. Read more about XHTML at the website "The World Wide Web Consortium". You can read more about XHTML at: http://www.w3.org
Search function
To make it easier for you web site visitors to navigate on your website it is an advantage if your site has a search function.
Site Studio provides a built-in function to create fully searchable websites without using server programming. You can see how it works by using the search function on this website.
Flash
There is built-in support for Flash in Site Studio.
You can add a Flash movie to the website as easily as adding an image.
Automatically generated menus
Menus are automatically updated as documents are added, deleted or changed. Therefore, there is no need to update menus on individual pages.
Even graphical menus (which use images) are updated automatically.
Site Studio creates necessary images on the fly.
Powerful image gallery functions
Site Studio has powerful image gallery functions for a versatile presentation of digital images.
Images can automatically be resized to a web format when imported.
There is no need for a separate image editing software to publish you pictures.
Actions (hyperlinks)
Actions suchs as hyperlinks are used to navigate to external or internal web pages. Actions also have "smart" links which allow for linking to the previous and next document.
Links can also be made to documents and other files within the project as resources.
Document groups
Document groups are used for grouping documents, i e document groups contain documents which are related in some way.
For example, a document group could contain all documents concerning a certain company issue.
A document group can be used as the source for menus making it easy to build custom menus.
Document Properties
Each document has a document body, i e it's content.
Additionally a document has several properties, such as the document title, date of creation, last modified date, primary colors, associated resource folders etc.
These properties are then used together with a layout and it's components to create a unique web page.
System Requirements
Operating System
Microsoft Windows 98/ME/NT4/2000/XP/2003/Vista
Software Microsoft Internet Explorer 6.0 or later
RAM 128 MB
Disk space 100 MB of existing disk space
CPU Intel Pentium, 500 MHz or equivalent
代碼:
Download Link: (Rapidshare)
http://rapidshare-is.blogspot.com/2010/01/part1_1711.html
No Pass
