【軟體名稱】:RRegistry Victor V5.5.9.4_免安裝
【軟體語言】:多國語言
【軟體分類】:系統工具
【檔案大小】:2.90 MB
【放置空間】:RapidShare/depositfiles
【解壓密碼】:no
【軟體介紹】:
Registry Victor 是專門設計來清潔和簡化你的 registry 以提升您的電腦效能。只要幾個簡單的滑鼠點擊,就可以幫你清除、修復和最佳化你電腦中的 Windows registry。Windows registry 通常是造成 Windows 損毀或當機、效能降低和出現錯誤訊息的原因之一。透過定期使用registry cleaner來修復registry錯誤,你的系統不但會比較穩定,也不需透過昂貴的硬體設備就能增加你系統的效能。
透過幾個簡單的步驟,Registry Victor就能掃描出你所有無效的或錯誤的registry名單,你能選擇性的清除清單中的任何一個項目或者選擇自動修復全部。為了方便和安全起見,Registry Victor也能製作備份檔,好讓您能輕易的恢復任何的變動。
Registry Victor™ claims to be the most advanced registry cleaner in pc diagnosis and repair. It can do a complete scan of the pc errors such as system slowdown, freezing, crashing and deadlock. Safely optimize the speed of system and set your PC in a fantastic performance!
Registry Victor™ is a top-ranking error-resolution registry cleaner which will fix the computer errors and optimize the system speed. Various annoying problems will gradually appear like slow speed, crashing or freezing, blue screen, deadlock, error messages etc. after your computer
Registry Victor™ uses the most advanced technology to scan your hard driver and give you a comprehensive diagnosis in seconds. Once the problems have been located, Registry Victor™ offers you a professional and highly-efficient solution to set your PC in a fantastic state! By using Registry Victor™ regularly, your system should not only be more stable but it will also help streamline your pc registry without expensive hardware upgrades.
Operating System: Windows NT/2000/2003/XP/Vista
確保下載的軟體能正常使用,請使用
