ATI又推出新卡啦~各位原本想要在CES上看的Fermi好像也沒太多情報流出,所以,就先看看ATI的Radeon HD 5670吧!
先說明一下Radeon HD 5670的規格:
Process:40nm
Transistors:627M
Engine Clock:775 MHz
Stream Processors:400
Compute Performance:620 GFLOPS
Texture Units:20
Texture Fillrate:15.5 GTexels/s
ROPs:8
Pixel Fillrate:6.2 Gpixel/s
Z/Stencil:24.8 GSamples/s
Memory Type:GDDR5
Memory Clock:1000 MHz
Memory Data Rate:4 Gbps
Memory Bandwidth:64 GB/s
Memory interface:128-bit
Typical Board Power:61W
Idle Board Power:14W
簡單來說,它的SP數量只有400個,很明顯地就是要切入中、低階等級的顯示卡區域。至於效能的位置,由於筆者手邊只有Radeon HD 5770,所以只好拿它來跟Radeon HD 5670做個比較了。
Radeon HD 5670 圖片一覽
Platform
Motherboard:GA-EX58-DS4(Intel X58 + ICH10R Chipset)
Processor:Intel Core i7-920(8M Cache,2.66 GHz,4.80 GT/s QPI)
Memory:Kingston HyperX DDR3 1066 8-8-8-20 1T(KHX16000D3T1K3/3GX)
Hard Drive:Seagate 7200.9 250GB
Power Supply:Silver Stone SST-ST1000
Display:SAMSUNG 2443BWX
OS:Windows 7 Ultimate(32bit)
Test Cases
3DMark Vantage BUILD 1.0.1
Crysis Hotfix 1.21
Call of Juarez Demo
Unreal Tournament 3 v2.1 Patch
S.T.A.L.K.E.R.: Clear Sky benchmark
S.T.A.L.K.E.R.:Call of Pripyat benchmark
Street Fighter IV Benchmark
The Last Remnant Demo
Devil May Cry 4 Demo
Heaven Demo v1.0
Direct Compute Bencharmk v0.35
Power Consumption
Temperature
VGA Driver
Radeon HD 5770
8.681-091124a-092498C
Radeon HD 5670
8.69-091211a-0932208E
Test Results
Radeon HD 5770高出Radeon HD 5670有67.68%的效能,而目前的Radeon HD 5770的價格在5000~6000台幣之間,Radeon HD 5670又是號稱主戰GeForce GT 240的情況下,應該會在將近4000元台幣左右的價格,隨後Radeon HD 5670才會慢慢降價下來,如果想要等便宜的ATI新卡,其實在三月的時候應該會是不錯的時間點。
Process:40nm
Transistors:627M
Texture Units:20
ROPs:8
Memory Type:GDDR5
Radeon HD 5670 圖片一覽
Platform
Test Cases
Crysis Hotfix 1.21
Call of Juarez Demo
Heaven Demo v1.0
Power Consumption
Temperature
VGA Driver
Radeon HD 5770
Radeon HD 5670
Test Results
