Quadro Certified 84.26@官方FTP
  • 主題發起人 主題發起人 micrortd
micrortd
nonwebsite.com
這裡
好像沒人貼 也來放一下
Issues Resolved in Version 84.26
• All GPUs, Windows XP Professional x64: Catia hangs when opening
a large file.
• All GPUs: The system freezes when using the full 4GB address space
with OpenGL applications.
• All GPUs: 100% CPU use occurs when running Houdini 8.0.410.
• All GPUs: I-DEAS and SpaceVision wireframe performance is poor
due to excessive memory consumption.
• NVIDIA Quadro FX4500: Avena PDMS - Overlay plane fails to
function correctly on the right hand monitor.
• NVIDIA Quadro FX 4500: Wrong colors and grey stripes appear
when running hardware accelerated HDV playback and preview.
• NVIDIA Quadro FX 3400/4400: When using display lists, there is a
performance drop with SolidEdge 17.
• NVIDIA Quadro FX 3450/4400, Windows XP Professional x64: Bluescreen
crash occurs when running After Effects 7 (x224).
• NVIDIA Quadro FX 4000: SolidWorks sketch preview shows entities
from the previous sketch.
• NVIDIA Quadro FX 4000, Windows Professional x64 Edition: Edge
Blending is not available.
• NVIDIA Quadro FX 3450, Windows XP Professional x64: 64-bit
Viewperf 8.1 performance decreases with DualView enabled.
• NVIDIA Quadro FX 3400: Lines disappear when the mouse cursor
moves over them in Solid Edge V17UP07.
• NVIDIA Quadro FX 3400 : DirectDraw overlays do not work with
Avid MediaComposer or XPressPro.
• NVIDIA Quadro FX 3400: CATIA experiences performance
degradation with Release 80 drivers.
• NVIDIA Quadro FX 1400/3450/4400: Memory leak occurs when
running Symphony Nitris.
NVI D I A C o r p o r a t i o n 5
Re l e a s e 8 0 V e r s i o n 8 4 . 2 6
• NVIDIA Quadro FX 1400: 3D applications run slower when
Dualview mode is enabled.
• NVIDIA Quadro FX 1400: Parity errors occur with memory-intensive
operations such as rendering, cloth simulation, etc.
• NVIDIA Quadro FX 1300, Windows XP Professional x64: The system
hangs intermittently when running 64-bit Viewperf 8.1 On Pro/E
Wildfire.
• NVIDIA Quadro NVS 440: Maya 6.5 crashes after starting up.
• NVIDIA Quadro NVS 280: When running Inventor11 and slicing a
part in Direct3D mode, blue corruption appears.
• NVIDIA Quadro4 380/550 XGL: Rendering anomaly occurs with
Inventor when slicing an assembly in OpenGL mode.
• NVIDIA Quadro4 980 XGL: StudioTools crashes when launching
more than one session.
推,昨晚我就已經換上了,測試分數雖然是差不了多少,但畫質及顏色有比84.43好,不會像84.43那樣會亮度太高而濛濛的(使用預設值時,畫面就有些白茫茫了)。 :PPP:
PS:
我這張N6600TD超怪的,用84.21~84.25版都會將fsp鎖定在60上跑,所以測試分數都爆低得可憐! ;ng;
mhp1120 說:
PS:
你軟改QUADRO嗎 呵呵
7系列殘念了
micrortd 說:
你軟改QUADRO嗎 呵呵
7系列殘念了
我就是完全都沒改(也沒有超頻),才會說這張卡怪! ;ng;
其實QUADRO的驅動程式也能安裝在一般的顯示卡上(支援名單上有列出來的話),只是畫質及顏色會好那麼一些些而以,例如之前的77.18也很不錯。
(我純粹是用來看影片爽的) :PPP:
PS:
最近幾版的QUADRO驅動程式我也都試過了,除了77.18之外就這版最順,其餘都會"鈍鈍"的。 ;oq;
Supported display modes for NV4_DISP.INF Version 84.26, 03/17/2006
[nv_SoftwareDeviceSettings]
// 0040 - NVIDIA GeForce 6800 Ultra/GeForce 6800 Series GPU
// 0041 - NVIDIA GeForce 6800
// 0042 - NVIDIA GeForce 6800 LE
// 0043 - NVIDIA GeForce 6800 XE
// 0045 - NVIDIA GeForce 6800 GT
// 0047 - NVIDIA GeForce 6800 GS
// 0048 - NVIDIA GeForce 6800 XT
// 004D - NVIDIA Quadro FX 3400/4400
// 004E - NVIDIA Quadro FX 4000
// 0090 - NVIDIA GeForce 7800 GTX
// 0091 - NVIDIA GeForce 7800 GTX
// 0092 - NVIDIA GeForce 7800 GT
// 0093 - NVIDIA GeForce 7800 GS
// 009D - NVIDIA Quadro FX 4500
// 00C0 - NVIDIA GeForce 6800 GS
// 00C1 - NVIDIA GeForce 6800
// 00C2 - NVIDIA GeForce 6800 LE
// 00C3 - NVIDIA GeForce 6800 XT
// 00CD - NVIDIA Quadro FX 3450/4000 SDI
// 00CE - NVIDIA Quadro FX 1400
// 0140 - NVIDIA GeForce 6600 GT
// 0141 - NVIDIA GeForce 6600
// 0142 - NVIDIA GeForce 6600 LE
// 0143 - NVIDIA GeForce 6600 VE
// 0145 - NVIDIA GeForce 6610 XL
// 0147 - NVIDIA GeForce 6700 XL
// 014A - NVIDIA Quadro NVS 440
// 014D - NVIDIA Quadro FX 550
// 014E - NVIDIA Quadro FX 540
// 014F - NVIDIA GeForce 6200
// 0160 - NVIDIA GeForce 6500
// 0161 - NVIDIA GeForce 6200 TurboCache(TM)
// 0162 - NVIDIA GeForce 6200SE TurboCache(TM)
// 0163 - NVIDIA GeForce 6200 LE
// 0165 - NVIDIA Quadro NVS 285
// 01D1 - NVIDIA GeForce 7300 LE
// 01DE - NVIDIA Quadro FX 350
// 01DF - NVIDIA GeForce 7300 GS
// 0211 - NVIDIA GeForce 6800
// 0212 - NVIDIA GeForce 6800 LE
// 0215 - NVIDIA GeForce 6800 GT
// 0221 - NVIDIA GeForce 6200
// 0240 - NVIDIA GeForce 6150
// 0241 - NVIDIA GeForce 6150 LE
// 0242 - NVIDIA GeForce 6100
// 0290 - NVIDIA GeForce 7900 GTX
// 0291 - NVIDIA GeForce 7900 GT
// 0292 - NVIDIA GeForce 7900 GS
// 029D - NVIDIA Quadro FX 3500
// 029E - NVIDIA Quadro FX 1500
// 0301 - NVIDIA GeForce FX 5800 Ultra
// 0302 - NVIDIA GeForce FX 5800
// 0311 - NVIDIA GeForce FX 5600 Ultra
// 0312 - NVIDIA GeForce FX 5600
// 0314 - NVIDIA GeForce FX 5600XT
// 0321 - NVIDIA GeForce FX 5200 Ultra
// 0322 - NVIDIA GeForce FX 5200/GeForce PCX 5300
// 0323 - NVIDIA GeForce FX 5200LE
// 0326 - NVIDIA GeForce FX 5500
// 0327 - NVIDIA GeForce FX 5100
// 0330 - NVIDIA GeForce FX 5900 Ultra
// 0331 - NVIDIA GeForce FX 5900/GeForce PCX 5900
// 0332 - NVIDIA GeForce FX 5900XT
// 0333 - NVIDIA GeForce FX 5950 Ultra
// 0334 - NVIDIA GeForce FX 5900ZT
// 0338 - NVIDIA Quadro FX 3000/Quadro FX 1300
// 033F - NVIDIA Quadro FX 700
// 0341 - NVIDIA GeForce FX 5700 Ultra/GeForce PCX 5750
// 0342 - NVIDIA GeForce FX 5700
// 0343 - NVIDIA GeForce FX 5700LE
// 0344 - NVIDIA GeForce FX 5700VE
// 0391 - NVIDIA GeForce 7600 GT
// 0392 - NVIDIA GeForce 7600 GS
// 039E - NVIDIA Quadro FX 560
tw159134 說:
效能&品質設定那邊 你有把垂直同步關閉嗎?
全部都是使用預設值,[已控制的應用程式]原本就是打勾的,我只有調整了[系統效能]至"效能"模式,以及[數位震動]推了半格而以。 ;em42;
這版84.26還算穩定,而且也不會有上述的狀況,終於可以把84.12換掉了。 ;face0;
PS:
之前已用77.18撐了滿久的時間,再來84.12也是沒有問題的(但預設的亮度比較暗),我想也許是這張卡並非公版設計的關係吧!? ;oq;
神奇的是
朋友的HP XW9300+QUADRO FX1400
工作站在換了驅動以後 跟我說
不會當機了@@
