求助IP分享器
  • 主題發起人 主題發起人 tw159134
tw159134
www.twcarpc.com
密碼一直錯誤不能進去
以下是機器的解除方法 但是我都看不懂...
3COM的分享器
原文如下..
Forgotten The System Password
If you've not set a System password before, the unit will accept the default password "admin". Remember that all passwords are case sensitive.
If you've changed the System password but cannot remember it, then the following procedure can be used to reset the whole unit back to the factory defaults. This will set the system password back to "admin" but unfortunately, it will also clear any configuration you may have already entered. We recommend you print this page before proceeding.
1. Unplug the power, and remove the all cables from the gateway.
2. Using an RJ45 cable, connect the gateway's Cable/DSL port to one of the LAN ports.
3. Apply power to the unit
4. The Alert LED will start to flash. Wait until the flash rate changes to 2 seconds on, 2 seconds off, continuously.
5. Unplug the power and re-connect your network as before.
6. Apply power.
7. The unit will now have the default IP address of 192.168.1.1 and subnet mask of 255.255.255.0. You should now follow the steps in the Installation Guide to re-install your gateway.
Originally posted by tw159134@Aug 25 2004, 03:38 PM
密碼一直錯誤不能進去
3COM的分享器
原文如下..
6. Apply power.
忘記系統密碼
第一個大致是說,你如果沒改過密碼,直接用"admit"即可.....(就是有改過才會需要看這篇啊.... ||| )
第二個說什麼你如果忘記你設的密碼,可以試試下面的步驟,就可以恢復出廠時的預設值"admit",但是你也會把你之前設定的其他東西一起移除,所以他也建議你先copy好這一頁以防萬一....(怕你到時不能上網吧) :ph34r:
1.拔除電源,並且移除所有在gateway上的線路(就是全部拔起來啦~ :LKJ: )
2.用條RJ45線路,接上gateway的Cable/DSL port到其中之一的LAN port上
3.接上電源??? :ph34r:
4.警示的LED會開始閃爍,等到燈的閃爍變成兩秒間格閃爍時(兩秒亮,亮秒熄),繼續下一步.
5.拔除電源並且移除你的那個啥米LAN port(和步驟1一樣吧,全拔嚕 :ph34r: )
6.再重開電源
7.此分享器的IP會回復到預設值"192.168.1.1",子網路遮罩"255.255.255.0",再來你必須依照安裝指南的步驟重新安裝你的分享器和所有線路
有錯別怪我,小弟沒認識幾個大字.... ||| :PPP: :OPP:
有遺漏的請各位大大補充&訂正... :lkl: :P
