求救...經常性藍屏...
  • 主題發起人 主題發起人 shu7474
shu7474
近期沒有換任何硬體,這兩個月可是卻開始經常藍屏...
有時候一天當N次,有時候三天沒當過...玩遊戲會當,看影片會當,上網也會當...
有時候是0X000124有時候0X00009C或0X000019....
不過下面的英文都是一樣的,不知道有沒有大大可不可以協助處理...
cpu i7-3820
mb asus p9x79 le
vga GTX480
ram 創見 4G*4
ssd 普傑 128g
power 酷媽 V650S(去年暑假換得)
沒有超頻...
硬體的問題.....先看是否是記憶體問題..先把記憶體拔下只插一隻試試 !!
轉貼 WIN7的
This bug check indicates that a fatal machine check exception has occurred.
*9C primarily appears on versions of Windows that predate Vista. For example, XP, Server 2003, etc. Nowadays, in Vista and later, we have *124 instead of *9C. However, in very uncommon cases, *9C is presented instead of *124 because the WHEA may not be fully initialized (Windows Error Hardware Architecture) or when a special processor issue on SMP systems occurs that is characterized by a failure with shared memory synchronization.
BugCheck 9C, {0, fffff880009f8b70, 0, 0}
Parameters 1, 3, and 4 are all 0 so I have no idea what happened here in this crash. Parameter 2 contains the address of the MCA_EXCEPTION structure which doesn't really help us in this case since the rest is 0.
There is only so much you can do with a bugcheck like this until it comes down to a faulty processor that will need to be replaced. Start from 1 and work downward:
1. Ensure your temperatures are within standard and nothing's overheating. You can use a program such as Speccy if you'd like to monitor temps - http://www.piriform.com/speccy
2. Clear your CMOS (or load optimized BIOS defaults) to ensure there's no improper BIOS setting - http://pcsupport.about.com/od/fixtheproblem/tp/clearcmo...
3. Ensure your BIOS is up to date.
4. The only software conflict that can usually cause *9C or *124 bugchecks are OS to BIOS utilities from manufacturer's like Asus' AI Suite, AI Charger software, etc. If you have something like this software-wise, remove it ASAP (which I see you do have Asus software installed).
5. If all of the above fail, the only left to do is replace your processor as it is faulty.
Regards,
Patrick Barker
From microsoft forum answered this for me.
Post can be deleted
ram 創見 4G*4<<速度多少的<<降一些試試
轉貼 WIN7的
Regards,
Patrick Barker
Post can be deleted
目前把ASUS的程式都移除了,希望能夠解決。
