[請教]玩天堂出現藍底白字>"<
舞秋月_佾江風
cpu:AMD SP2800+
ram: A-DATA 256 *2 DDR400
mb:asus a7v880
hd: ST-80G /8M
顯示卡:MSI 5700SP
系統:WIN XP SP2
只有玩天堂會這樣~~~ :|||: :|||:
請教一下我朋友電腦為什麼會這樣 :OO: :OO:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you're seen this stop error screen,restarst your computer.If this screen appears again,follow these steps:
check to be sure you have adequate disk space,If a driver is identiffied in the stop message,disable the drive updates,Try changing video adapters.
check with your hardware vendor for any BIOS update.Disable BIOS memory options such as press F8 to select Advanced startup options,and then select safe mode.
**STOP:0x0000008E(0xC0000005,0xBF870406,0xF4676438,0x0000000 0)
**win32K.sys-Address BF870406 base at
**BF800000,DateStamp 3b7de698
驅動用多少的?
有無超頻?...
那個win32的錯誤有點像cpu上不去的樣子..
Originally posted by Hili@Mar 15 2005, 12:44 AM
有無超頻?...
沒有 超頻~ :OO:
應該是顯示卡驅動吧~ :OPP:
我試試看嚕~!! 謝謝哩
Originally posted by kain2000a@Mar 15 2005, 01:47 AM
換driver應該就ok了..
把顯卡driver換成7x.xx...
我幫別人換成75.90就ok了!! :lol:
OKOK 我試試看嚕!! mooon mooon
