OPB的CI super pi 理論大公開
狂少
Bulletproof Themer
聽說有人要吐我用加速器跑super pi 1.5mod?
真的是逼我我上梁山是嗎?
跑不贏就閉嘴嘛
我覺得很度爛耶..
好阿...我就公佈我剛在國外發表的Cut-Integrance IV 理論
我就是能這樣跑..咬我嗎?
result first:
by far, my personal the best 3.6g fastest 1m and 32m
OK, here is the scoop...
basically you ned to do the prepare thing like I stated previously, now instead of copy-waza, please do this:
OPB CDT-IV from here:D
1st step:
make the pagefile exactly 512~512mb under the partition you place super pi 1.5mod
make a new folder named whatever you like , make 3 files which size can be about{ 600m(628666368)--->maxmem (I set), and pplus 32m..}x 3
2nd step:
use winrar to make the single rar files ...so it will be smaller or equal to 2gb, if you fail during compress....you know your setting ddefinitely haas problem on it.:)
2a. run the window of wuper pi 32m (or even 1m) set the size you wanna run...and leave the dialogue there.
3. Cut this rar file and paste @ C:/ for 3 timess.
** check with task manager for the available memory size...so let the system idle for at least :
20seconds for 1m
45 second for 32m
1m need to be greater than 460m
suggestion from OPB..:
you will need to do above BEFORE you use setfsb or clockgen to OC your FSB and change your memory parameters from memset.
Good luck.
**you also can use cut-paste -copy ...this is what I will try to do the experiment with CDT-V
the file is like this...
632m(about) need 3 of them...no ned to be exactly, but need to be only 3..
cuz not like you stated above..that would do it like 6 or more...that would completely mess the sequential compress action up.;)
when you run super pi, you need to choose size right?
after you choose , the dialogue will show:
"now start to calculate"
just stop there and do whatever need to do
reason:
cuz at that moment, you system has about to prepare some elments need to running super pi size you set...very important.;)
you cut the file , your ram is tempoarily store that img some address,
certainly you always cut from D to c..I did say from where you place the super pi folder right?
so after you paste on c...right click your mouse...can you do one more...two again?:D...
it will ask you "overwrite it..."
ok ..you need one folder.. only one for entire CDT-IV
why ? becuase you need to make it into a rar files..
so only ...ONLY make a folder ..and you will need to find 3 files are about 632m( 600m+32m is the hint for thinking why..but doesn NOT have to be 600+32..(I can have 598+34? right?...)
so the best way is you only make it once for 632mb for instance, then copy it into the folderright? then re-name the original to othername and copy into that folder...so now your folder has how much? 1264mb? so the one remain out side the folder still 632mb right?:D
so rename again and "cut it and paste into that folder...
now, if you install winrar already, right click that folder, and make a whatever name of the rar file...there we go, after done...you know what to do...
**All this way above is NOT must do like this...it's only one of the 1000 ways...to form you a 1.8g~2.0gb single rar file....
but why I give the hint for 3x(600mb+32mb) to form that single rar?...haha..
for everyone:
if you wanna integrate Copy-waza, please, after you do Cut and paste , copy from c to D and then you will need to paste @ d over-write for 2 times..., you will get the most surprised result.
here we go for elementry scool dialogue:D
will post real procedure during making this.:)
during the initial small file make up:
1st step completed; First C.I formed;)
2nd step initializing:
see that difference between available memory and system cache?
then...
** Anti-derevitive?lol 3 times from wherever to D ;)
Finalize the final step of CDT-iv...Cut...(Dereivitive in calculus?)
the final step, idle and let system balance, close the task manager and you're redy to go.:)
狂少
Bulletproof Themer
忘記講
有那一種加速器可以在super pi 1.5上作弊的麻煩跳出來表演給我看一下
但是我的理論可是有很多證人哦?;)
狂少
Bulletproof Themer
怎樣,沒人覺得是真的嗎?
還是以後我就不分享算了?
台灣人最大的悲哀...不團結...;smash;
sonicsallen
这两个Pi实在是太快了;nq;
对狂大的崇拜又更进一步
k08645151
不是不團結 是看不懂拉;oq;
當然相信狂大;em25; 開加速 對狂大有啥好處;director;
請狂大繼續發些教學文 造福大家:MMM:
Second2
剛睡飽馬上眼睛一亮...有夠快...不過那幾張圖我還是摸不著頭緒...繼續研究中...
CBB的網友們,看到大師出來講解,還不上來彭場一下,真是不應該...
salunt
Silent Link
基本上狂少的文
為了表示尊重,沒看懂我是不會回應的
像之前FYI給敝人的圖我到現在還弄不是很懂
然後又一直在忙present
所以一直沒有回應
絕對不是因為不捧場或是不團結的;rr;
lgs0809
大海管理 員
正在消化中,感謝大大分享這麼棒的文章。
狂少
Bulletproof Themer
喔..我不是因為不回應會如何
只是指著我鼻子說我用加速器的就是我們自己台灣人...
殘念...
