ETGATE Data Backup 2.0.405
INFO
Download FileSonic
INFO
NETGATE Data Backup 2.0.405.0 | 3.5 MB
NETGATE Data Backup is an effective tool to backup your files, photos, music and any important data on your PC. With NETGATE Data Backup you can even backup your MySQL/PHP databases from your webpage or your blog. Defragment and backup your registry with one simple click. NETGATE Data Backup supports scheduling of automatic backups at specified time. For extended security user has the option to encrypt or compress backuped files.
Data Backup Features:
- Backup - backup of your files, photos, music and important data on your PC.
- Database Backup - backup of your MySQL databases running on PHP supported server, suitable for backup of you web sites and blogs.
- Registry Defragmentation
- Registry Backup and Restore
- Startup Manager - manages all applications that starts at Windows startup
- Uninstall Manager - handy tool for quick uninstall of application from your system
- Compression support - backuped files can be compressed using bzip2 compression method
- Encryption support - backuped files can encrypted using user supplied key/password.
- Scheduling support - backup can be scheduled at specified time
- Multilanguage translation support
- Skin support
- Premium technical support
Home Page - www.netgate.sk
Download FileSonic
代碼:
http://www.filesonic.com/file/YD9Wg7k/
