【軟體名稱】: µTorrent 2.0 Build 17539 Beta/ 1.8.5 Build 17414/ 2.1 Build 17350 Alpha
【軟體語言】:多語
【軟體分類】:檔案傳輸
【軟體性質】:免費
【檔案大小】:476 KB
【放置空間】:badongo/ nakido
【解壓密碼】:no
【軟體介紹】:
很小巧的BT客戶端程序,擁有常見的功能,但是不支援UDP的連接協議。內網下載方面也有不錯的表現,外網就更不用提了。支援多任務同時下載,支援設置文件下載優先級,可以根據計劃任務調整占用的帶寬,全局/單個任務的速度限制,快速斷點續傳機制,支援UPnP,支流行的BT擴展協議,支援使用者來源交換,支援DHT最小內存占用僅6MB!
Changes in Version 1.8.5 (build 17414), 2009-11-25:
- Fix: catches crashes in bad DLLs
- Change: relaxed the requirements on bencoded integers to parse some broken torrents
- Fix: fixed uTP crash in edge condition
- Fix: Fixed HTTPS connections where received response was more than one packet
Changes in Version 2.0 Beta (build 17539), 2009-12-09:
- Change: Added auto restart feature for use in minimized mode.
- Change: on Windows 7 default to not minimize to tray
- Change: silently add multiple torrents when more than 5 torrents are added using drag'n'drop
- Change: tell user about buggy 3rd party software that might degrade uTorrent performance
- Fix: Transfer Cap tab in preferences would display incorrect Uploaded / Downloaded
Changes in Version 2.1 alpha (build 17350), 2009-11-18:
- Fix: accept magnet links through add-url webUI
- Fix: More strict https connection state management for halfopen accounting.
- Feature: A new tunable option in advanced setting for failover peer speed threshold
- Fix: Problem during install toolbar offer
- Fix: svn revision in PeerID on PPC now takes endianness into account
- Fix: added socket state logging when draining read socket to prevent false asserts
- Change: fixed nationalization support so it no longer depends on Windows functions
- Change: added checks for heap corruption that caused crash in uTP
- Change: improved stability by making all executable pages not writable
- Fix: fixed stack overflow when copying peer list
- Fix: fixed allocation regression in connection to peers
- Change: enable multiple instances of the client to run on multi-user machines (e.g. fast user switching)
- Fix: fixed crash when icmp.dll wouldn't contain the expected functions
- Fix: fixed crash when closing add torrent dialog while dragging a column
µTorrent 1.8.5 Build 17414
µTorrent 2.1 Build 17350 Alpha
確保下載的軟體能正常使用,請使用
