【軟體名稱】:µTorrent 2.0 Build 16222 Beta
【軟體語言】:多語
【軟體分類】:檔案傳輸
【軟體性質】:免費
【檔案大小】:336 KB
【放置空間】:badongo/depositfiles
【解壓密碼】:no
【軟體介紹】:
很小巧的BT客戶端程序,擁有常見的功能,但是不支持UDP的連接協議。內網下載方面也有不錯的表現,外網就更不用提了。支援多任務同時下載,支援設置文件下載優先級,可以根據計劃任務調整占用的帶寬,全局/單個任務的速度限制,快速斷點續傳機制,支援UPnP,支援行的BT擴展協議,支援用戶來源交換,支援DHT最小內存占用僅6MB!
Changes in Version 2.0 Beta (build 16222), 2009-08-20:
- Feature: Added versioned help files.
- Fix: Setup guide fixes
- Fix: installer with UAC
- Fix: Allow UDP trackers in the first tier when creating torrents
- Fix: UDP Tracker retries three times instead of two
- Fix: potential crash in installer
- Fix: Crashes when removing labels
- Fix: selection of labels over 256 characters in length
- Fix: multiple HTTP download crashes
- Fix: http seed fix for multifile torrents
- Fix: uTP connections that are upload rate limited will not have their max window size grow indefinitely
- Fix: Vista and Windows 7 FW rules are created for all profiles
為確保下載的軟體能正常使用,請使用
