Mediachance Dynamic Auto Painter v2.5.3 模擬繪畫效果 (RAR@57.6MB@多空間)
yohoman0000
【檔案名稱】:Mediachance Dynamic Auto Painter v2.5.3 神奇模擬繪畫藝術效果(圖轉畫)
【軟體語言】:多國語言(含繁體中文)
【軟體類型】:美工繪圖
【檔案格式】:RAR
【檔案大小】:57.6MB
【壓縮密碼】:無
【上傳空間】:Wupload/Easy Share/Filesonic/FreakShare
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
[font=標楷體]動態自動畫家獨特的方案,使您可以將照片變成繪畫,用繪畫的世界上最有名的藝術家模擬技術。不像其他類似的工具,動態自動畫家並不沒有改變圖片本身,它只是使用的原始圖像,從中自動繪製的新形象使用適當的筆刷和樣式。這樣你可以觀察工作方案,作為該藝術家的作品。該函數模擬了真實的畫布和塗料實際帆布的質感。比PS的濾鏡更細緻,效果更好,轉換過程非常詳細.你甚至能看到「畫」的過程,完成圖像看起來像畫。
Overview
Dynamic Auto-Painter works differently from normal effects. Instead of changing the pixels of the photo itself, DAP uses the input image only as a guide to paint the scene with many different brushes and guided by real-world artists inspired techniques.
"In a nutshell, Dynamic Auto-Painter not only emulates the technique but also the way different painters would see the same scene"
Looks like painting even from a distance
One thing that puts DAP2 above others is that the output images will look like a painting even in small size (for example resized on web or looking from a distance when printed). This is normally a common deal-breaker with any automatic filters which when resized down will start look back like a processed photo.
Looks like painting up-close
Looking at details you may think we are showing you a real canvas. An in some sense it is actually true. There is an option in the software called Real Canvas that simulates the way a real canvas or artistic paper interact with a paint. There is enough details even for a largest print.
Features
* In a Nutshell
- Real-world artists inspired techniques
- It doesn't depend on the input image resolution
- Add Non-traditional look to your photos or boring 3D renderings
- Versatile output
- Great easy to use interface
- Integrated help
- It is fun
* Full of Surprising results
The arbitrary nature of the painting process is ready to uncover many surprises in your images.
* Great Feedback tool for creative minds
Dynamic Auto-Painter can work as a great feedback tool to improve your photography skills. A painting will simplify the image to its core visual values allowing you to evaluate the overall impact of the image such as proper framing technique or good separation of subject from its surrounding.
* Looks Good when Printed
Unlike many off-the shelf painting effects the printed results from DA-Painter look stunningly painting-like. The Real Canvas option will add Canvas or watercolor Paper feel to the whole image even when printed on a normal non-textured paper.
Note: We recommend to use the printing application that come with your printer for best formatting. You can also use the Windows Photo Gallery (it is part of Windows Vista / Win7)
* Add a new dimension to your creative tool-box
Both designer professionals and home users can appreciate the new creative dimension of a painting style as a counter point to the abundance of digital photography.
* Versatile tool
If you feel like to create your completely new preset from scratch, you can. The interesting thing is that the set of brush strokes can be anything from colors to pictures of vegetables or coffee beans so you can really go wild.
System Requirements
Wimdows 7, Vista or XP (32-bit or 64-bit editions)
1 GHz processor or better
2 GB of RAM
1 GB of free disk space
Minimum screen resolution: 1024 x 768 (highly recommended higher resolution)
Install Notes
Install the program and register with one of the given serials, or use the keygen.
[/font]
下載地址: (等待5秒再按下右上的Skip AD就可到下載頁)
Wupload載點
Easy Share載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載 (等待5秒再按下右上的Skip AD就可到下載頁)
JDownloader載點 || JDownloader後備載點
各空間等待時間為10至30分鐘,本身是該空間之Premium用戶則無以上問題
請勿使用續傳軟體抓取(如迅雷、Flashget等等),以免抓取失敗或抓到不完整檔案
打開壓縮檔案的必要工具(等待5秒再按下右上的Skip AD就可到下載頁):
WinRAR 4.0 32bit / 64bit
32bit載點 || 32bit後備載點
64bit載點 || 64bit後備載點
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
1.僅供網路測試無任何販售行為及獲得任何利益!請於測試完後24小時以內將檔案刪除!
2.請支持正版!本檔案的提供純為試看用途,請勿作商業上之用途!!!!請於下載完後24小時以內將檔案刪除!!!
