[龍]WDC官方不建議Desktop系列硬碟使用在RAID磁碟陣列環境下
  • 主題發起人 主題發起人 ST-15K.3
ST-15K.3
我是恐龍..
http://wdc.custhelp.com/app/answers/detail/a_id/1397
Western Digital manufactures desktop edition hard drives and RAID Edition hard drives. Each type of hard drive is designed to work specifically as a stand-alone drive, or in a multi-drive RAID environment.
If you install and use a desktop edition hard drive connected to a RAID controller, the drive may not work correctly. This is caused by the normal error recovery procedure that a desktop edition hard drive uses.
Note: There are a few cases where the manufacturer of the RAID controller have designed their cards to work with specific model Desktop drives. If this is the case you would need to contact the manufacturer of that controller for any support on that drive while it is used in a RAID environment.
When an error is found on a desktop edition hard drive, the drive will enter into a deep recovery cycle to attempt to repair the error, recover the data from the problematic area, and then reallocate a dedicated area to replace the problematic area. This process can take up to 2 minutes depending on the severity of the issue. Most RAID controllers allow a very short amount of time for a hard drive to recover from an error. If a hard drive takes too long to complete this process, the drive will be dropped from the RAID array. Most RAID controllers allow from 7 to 15 seconds for error recovery before dropping a hard drive from an array. Western Digital does not recommend installing desktop edition hard drives in an enterprise environment (on a RAID controller).
Western Digital RAID edition hard drives have a feature called TLER (Time Limited Error Recovery) which stops the hard drive from entering into a deep recovery cycle. The hard drive will only spend 7 seconds to attempt to recover. This means that the hard drive will not be dropped from a RAID array. While TLER is designed for RAID environments, a drive with TLER enabled will work with no performance decrease when used in non-RAID environments.
WD DESKTOP系列硬碟有錯誤時,硬碟會進入deep recovery cycle模式,並進行2分鐘的修復動作,一般磁碟陣列控制器僅允許修復7~15秒,因此當硬碟沒有回應時,硬碟將被控制器視為故障,因此WD不建議使用WD Desktop系列硬碟用於磁碟陣列環境之下
終於搞懂了
感謝解惑
受益良多
那WD桌上型的黑標藍標HD
定意就有點模糊
看一下
我可以去買
WD1003FBYX
常用 WD 的朋友可能要注意一下是否有 RAID 的需求..... 沒在用 WD 的人,應該沒差啦!
沒差拉...
之前RAID都玩多久了
也沒遇到上面這問題
大都是自己壞軌死掉的
挖哩勒..我的WD黑標也列入了
用了RAID0已經一段時間說
這......好像很早以前就有的消息了,可以透過2個程式來做修正....用WDC推出的官方軟體 WDTLER.EXE
關掉它就對了,還有一個省電功能在官方網站就有得抓工具程式 wdidle3 ,可以利用它來設定硬碟機多久會進入
閒置狀態或關閉這個功能 這兩個都關要關閉.....差不多就可以過著快樂的日子了....
WDTLER 對現在的硬碟都無效咧..
提醒 mizuki兄這些程式不可以亂用
之前傳說綠標會自動返回磁頭造成來回時間暴高,所以用wdide3可以修正
偶自己4顆綠標2TB修正後就組RAID,大約半年後葛屁!連著眾mm一起帶走....;smash;
現在都不敢用WD綠標了....;em44;
還好......現役的是用日立的做0+1
不過舊的那一台還是2顆藍標做0說
反正.....還沒有給我出過問題就是了XD(大幸)
