【軟體名稱】:jv16 PowerTools 2011 v2.0.0.1000 Beta 6~免安裝
【軟體語言】:多國語言
【軟體分類】:系統工具
【軟體格式】:RAR
【檔案大小】:8.08 MB
【放置空間】:depositfiles/ mediafire
【解壓密碼】:no
jv16 PowerTools2008 為您提供對Windows系統的全面管理、控制,可用於登錄檔、檔案系統和本機網路的監控與優化。登錄'檔工具可以維護Windows 加入/刪除軟體清單;移除軟體;掃瞄登錄檔中的無效鍵值;刪除無效內容;控制系統啟動時加載的程式;電腦的登錄檔。檔案系統工具能搜索本機電腦中的零長度檔案、重複檔案、臨時檔案、無效快捷方式等。設定好就能加速PC執行!
What's New in jv16 PowerTools 2011 Beta:
1. Tag System - allows you to tag individual lines.
2. The Software Uninstaller has been fully rewritten. Both its ability to find software from the computer, and its ability to uninstall software have been greatly improved.
3. User Action History feature - allows you to see exactly what you have removed with the program in the past.
4. The Registry Cleaner now shows detailed information specific pieces of registry data was listed as error.
5. The Startup Manager is now fully compatible with msconfig. This means that you can use jv16 PowerTools to enable items disabled with msconfig, and vice versa.
6. Remove on reboot - feature in the File Tool allows you to delete protected or locked files during the next system startup (assuming the protection is not yet active).
7. Settings window now uses scroll bars in order to display all the settings with smaller window sizes.
8. Accuracy and safety improvements to the Registry Cleaner engine.
最強的免費空間下載器~免安裝
JDownloader 0.9.580~免安裝
確保下載的軟體能正常使用,請使用WinRAR 最新版本解壓![]()
WinRAR 4.00 Beta 5~中文版(32 位元)
