以下正體中文是 "GOOGLE翻譯" 自翻的!...嗯!有點遜!
Picasa,可以幫助你即刻找到,編輯和分享上的您的的的PC中的的所有圖片。
每次打開Picasa時,它會自動查找您的所有圖片(甚至是那些您已經遺忘)和各種他們將舉辦日期與文件夾的名字,你會承認的視覺專輯。
你可以拖放操作來排列相冊,和標籤來創建新組。 Picasa保證您的圖片從始至終都井井有條。
Picasa還可以簡單的一鍵修復和強大的影響將在您的指尖高級編輯。和Picasa分享您的照片,一個單元,您可以通過電子郵件,在家打印圖片,製作禮品CD,即時分享您的圖片和相冊,甚至發表自己的博客上的照片。
最新版本包括網絡相冊(連同其他改進),但需要您的要求,從谷歌帳戶。
原文:
Picasa is software that helps you instantly find, edit and share all the pictures on your PC. Every time you open Picasa, it automatically locates all your pictures (even ones you forgot you had) and sorts them into visual albums organized by date with folder names you will recognize. You can drag and drop to arrange your albums and make labels to create new groups. Picasa makes sure your pictures are always organized.
Picasa also makes advanced editing simple by putting one-click fixes and powerful effects at your fingertips. And Picasa makes it a snap to share your pictures, you can email, print photos home, make gift CDs, instantly share your images and albums, and even post pictures on your own blog.
The latest version includes Web Albums (along with other improvements), but requires that you request an account from Google.
Picasa 3.9 新功能
Picasa 3.9 可讓您將相簿內容直接分享到 Google+,並且提供更多樣化的編輯工具。如要進一步瞭解改版部分,請參閱 Picasa 3.9 指南。
如要下載 Picasa,請前往 http://picasa.google.com。
Title:
Picasa 3.9 Build 136.04
Filename:
picasa39-setup.exe
File size:
14.56MB (15,267,728 bytes)
Requirements:
Windows XP / 2003 / Vista / Windows7 / XP64 / Vista64 / Windows7 64
Languages:
Multiple languages
License:
Freeware
免費
Date added:
June 5, 2012
Author:
Google
www.google.com
原文:
Picasa 3.9 新功能
Title:
Filename:
picasa39-setup.exe
File size:
Requirements:
Languages:
Multiple languages
License:
Freeware
免費
Date added:
June 5, 2012
Author:
www.google.com
