【軟體名稱】:IsoBuster Pro 2.6 Build 2.5.9.5 - Beta_免安裝
【軟體語言】:多國語言
【軟體分類】:燒錄程式
【軟體性質】:共享
【檔案大小】: 3.51 MB
【放置空間】:RapidShare/depositfiles
【解壓密碼】:no
【軟體介紹】:
ISO破壞者,支援多種影像檔格式的燒錄輔助程式,可以讓你預灠影像檔中的檔案結構,還可以將 Video CD 的 DAT 檔轉成 MPG。
IsoBuster 是一個相當特殊的檔案工具,它最主要且容易被人注意的功能,就是它能直接讀取光碟映像檔中內含的檔案格式及內容,對於燒錄一族來說,算是一個不錯的燒錄輔助工具;另外,它還具有蠻特別的光碟讀取及檔案格式轉換功能。
Changes in IsoBuster 2.6 Beta:
Changes compared to version 2.5.5:
* Unicode support via all aspects of the Graphical User Interface (GUI), Dialogs etc.
* Full Unicode support during the installation (e.g. install Chinese on a US system etc.)
Changes compared to version 2.5:
* Expert Witness Format image-file support (*.E01, *.S01, *.L01)
Improvements compared to version 2.5.5:
* Ability to select text encoding (Unicode, ANSI, UTF8, ..) when saving text from the editor window
* Ability to select text encoding (Unicode, ANSI, UTF8, ..) when saving file-system data (e.g. file-list) to a text file
* Implemented *.qic file-type recognition for found files based on their signature
* During extraction of *.M2TS files, and when there's an error, the replace with zero block option is now available
* Added support for localized Bytes / KB / MB / GB / TB when displaying a byte size (for instance in the right panel)
* Implemented a workaround for badly mastered Roxio (Retrieve) UDF discs, possibly in combination with spanning several discs
* Various other GUI improvements
Improvements compared to version 2.5:
* Improved support for Japanese text in DVD-VR Label and Title
* Implemented *.orf file-type recognition for found files based on their signature
* Implemented *.ncd file-type recognition for found files based on their signature
* "Do not bother me with this message" option in message when going online
* Command line parameters: "/nodrives" and "/nosplash"
* Improved error message when it's impossible to open or create a file
* Improved font support in the editor window when displaying text other than sector view
* Do not prompt to make a CUE file if the actual image file was deleted after errors
* The Windows shell command "extract" will now start with "/nodrives"
Fixes compared to version 2.5.5:
* Fixed rare and not likely to happen crash during scanning for missing files and folders on a particular dataset where structures resembled FAT but were not.
Fixes compared to version 2.5:
* The program now prompts to overwrite a resource-fork-only file on an NTFS system (rare situation)
* Fixed double prompt for action when NTFS stream(s) and the main file would contain read errors
* When tracks are dragged and extracted, but are split into muliple files, all subfiles are now moved as well from the Drag temp folder to the final folder
* Fixed very rare instance where aborting extraction of a track would cause the next track to be skipped entirely
IsoBuster Pro 2.5.5 Build 2.5.5.1 - Final_安裝版
IsoBuster Pro 2.5.5 Build 2.5.5.1 - Final_免安裝
確保下載的軟體能正常使用,請使用
