IsoBuster 2.8.4/ IsoBuster 2.8 - Final 光碟映像檔工具~免安裝
  • 主題發起人 主題發起人 le2712
le2712
【軟體名稱】:IsoBuster 2.8.4 Beta/ IsoBuster 2.8.0.0 Final~免安裝
【軟體語言】:多國語言
【軟體分類】:光碟相關 (光碟工具)
【軟體格式】:RAR
【檔案大小】: 3.11 MB
【放置空間】:depositfiles/ mediafire/ x7.to
【解壓密碼】:no
ISO破壞者,支援多種影像檔格式的燒錄輔助程式,可以讓你預灠影像檔中的檔案結構,還可以將 Video CD 的 DAT 檔轉成 MPG。
IsoBuster 是一個相當特殊的檔案工具,它最主要且容易被人注意的功能,就是它能直接讀取光碟映像檔中內含的檔案格式及內容,對於燒錄一族來說,算是一個不錯的燒錄輔助工具;另外,它還具有蠻特別的光碟讀取及檔案格式轉換功能。
Changes in IsoBuster 2.8.4 Beta:
* A great deal of new extensions were added to the signature detection which happens during a search for missing files and folders. Besides a large number of various files, picture formats and multimedia files there's now also accurate detection of documents such as: *.wpd, *.sdw, *.odt, *.sxw, *.sxc, *.sxi, *.sxm, *.std, *.ott, *.ots, *.ods, *.odb, *.odg, *.odf, *.odp, *.wb2, *.nsf, *.max and most Office document formats, such as *.doc, *.docx, *.xls, *.xlsx, *.ppt, *.pptx, *mdb, *.pst, *.pub, *.vsd, *.rtf, *.db, *.one, *.wri, *.msi
* Command line support has been enhanced with a large number of new parameters and combinations. Besides initiating "/scan" and extracting the files found based on their signature "sig:" there is now also the possibility to extract "all:" tracks / sessions / file systems, dynamically change the names of the extract-to files or folders, export file-lists ("/tree") based on a number of parameters/ tokens etc. Best check the details in the help file for more information
Improvements:
* UDF scan for missing files improvements, so that in case of many references to VAT tables not the same sectors are read again and again, and so that duplicate UDF FS are not listed anymore
* Updated EWF support to the latest and greatest status of the LibEWF project
* Ability to "OK to all" on Windows IO errors during extraction to avoid X amount of such dialogs when multiple files are processed
* Always display a message after a forced online check, even if it is the most recent version, and even if the user set not to display beta or final version warnings
* The cue file full path was displayed in the Save Dialog control instead of only the filename.
* Various other GUI improvements
Fixes:
* Small issue that caused some DVD IBP/IBQ images to be recognised as CD, so that they could not be completed anymore
* Small issue that caused some IBP/IBQ images with gaps to be reported without gaps
* Fixed a very rare crash caused by a buggy UDF file system, while scanning for missing files and folders.
* The md5 file was not put in the proper folder when set to create automatically after image file creation.
* Fixed issue that caused the last found file, based on its signature, to be one block short in length.
Homepage - www.isobuster.com
最強的免費空間下載器~免安裝
JDownloader 0.9.580~免安裝
確保下載的軟體能正常使用,請使用
WinRAR 最新版本解壓
WinRAR 4.00 Beta 3~中文版(32 位元)
