GPU-Z v0.5.1 支援GTX 560 Ti
  • 主題發起人 主題發起人 iccs
iccs
0.5.1
•Added support for NVIDIA GTX 560 Ti, 480M, 485M
•Added transistors and die size for 460M, 445M, 435M
•Added release date for 6800 GT, 6600 GT, 6600, 6200, 8800 GTX, 8800 GTS, 8800 Ultra, 8600 GTS, 8500 GT, 8800 GS, 9600 GSO, 8800 GT, GTS 250, GT 440
•Added preliminary support for AMD Zacate and Ontario APUs
•Found a new way to disable NVIDIA's power limiter
•Added support for GTX 570 and GTX 560 to power limit disable function, the parameter is now called /GTX500OCP
•Fixed crash in sensors panel
•Acer PCI vendor now using a shorter text that fits the field width
•Added CHL8214 & CHL8226 support for AMD Barts and Cayman
•Improved the automatic update check to run completely in the background and only appear when an update is available (manual update check is unchanged)
官網下載
哇咧~真歹勢 煩請C大刪文><
