Glary Utilities Pro 2.40.0.1326 + KeyGen
INFO
Download FileSonic
INFO
Glary Utilities - a collection of system tweaking and utilities for tweaking, improving overall productivity and protect your PC. This application allows the user to get rid of unnecessary files from the old records and history of Internet activity, by installing various plug-ins, can achieve full compatibility of applications with more than 45 different programs. Furthermore, Glary Utilities optimizes the use of system memory, find, and fix or remove broken Windows shortcuts, manage the programs that start with the operating system, and removing these applications. Has a multilingual user interface
Glary Utilities is a collection of system tools and utilities to fix, speed up, maintain and protect your PC. It allows you to clean common system junk files, as well as invalid registry entries and Internet traces (theres a plug-in support for 45+ external programs). You can also manage and delete browser add-ons, analyze disk space usage and find duplicate files.
Features:
• Disk Cleaner Removes junk data from your disks and recovers disk space
• Registry Cleaner Scan and clean up your registry to improve your system’s performance.
• Shortcuts Fixer Corrects the errors in your startmenu & desktop shortcuts
• Startup Manager Manages programs which run automatically on startup
• Memory Optimizer Monitors and optimizes free memory in the background
• Tracks Eraser Erases all the traces,evidences,cookies,internet history and more
• File Shredder Erases files permanently so that no one can recover them
• Internet Explorer Assistant Manages Internet Explorer Add-ons and restores hijacked settings
• Disk Analysis Get details information of the desired files and folders
• Duplicate Files Finder Searchs for space-wasting and error producing duplicate files
• Empty Folders Finder Find and remove empty folders in your windows
• Uninstall Manager Completely uninstall programs you don’t need any more
• Context Menu Manager Manage the context-menu entries for files, folders…
• Process Manager Monitor programs that run on your PC and stop spyware and Trojans.
Download FileSonic
代碼:
http://www.filesonic.com/file/S9hhq2L/
