軟體簡介:
獲得許多獎項肯定的防毒軟體保護您的電腦遠離病毒, 木馬, 間諜程式和其他惡意程式. 除此之外, Kaspersky Anti-Virus 6.0 保持您的電子郵件和即時傳訊能夠遠離危險的蠕蟲. 互動的防護機制也整合了最新的免疫防護技術提供更有強的安全等級, 自動更新機制確保不中斷的安心防護.
Change Log:
1. Support for Windows XP 64-bit has been added (except for the pro-active protection module and plug-ins for MS Outlook and Outlook Express mail clients).
2. File Anti-Virus
- "Scan mode" setting
- Schedule for pausing the scan and file anti-virus tasks on events "application start up/exit"
- Resolving the username and the name of the computer from which the access to infected files is attempted
3. On-Demand Scan Tasks
- The ability to configure operation in the "Scan for Active Infections" using the "Disinfect active infections" setting
- All lists have been revised to include the ability to edit components (scan task objects, exclusion masks, PDM paths, etc.)
- The settings for controlling the system load depending on external tasks running has been added to all scan tasks
- Quarantine storage scan object has been added
- The start-up objects scan scope has been extended for 64-bit versions of Windows OS
4. Proactive protection
- Detection of a number of keyloggers types has been added
- Windows Task Manager protection against malicious dll (that are often used by rootkit software) has been added
5. Updating
- The ability to perform updates from the Administration Server has been added
- An update copying (updating from shared folder) task has been added for all types of updates (updates of the database, application modules, etc.)
6. General properties
- An option has been added to scan data transmitted via secure connections (SSL) using E-Mail Anti-Virus and Web Anti-virus.
- The ability to use the system environment variables when specifying objects to be scanned, scan exclusions, Anti-Hacker rules and proactive
protection module has been added
- The ability to register any types of events in the Windows events log has been added (including the ability to select the type of log - system or user log)
- Utility for product protection against failures has been revamped: all processes of the product "monitor" each other and automatically restart closed processes
- The product's command line interface has been revised
Download
Change Log:
2. File Anti-Virus
5. Updating
Download
