【更新】K-Lite Codec Pack 2.78 (Full)
Ethan.CPA
台北
Change Log:
- Updated Media Player Classic (latest build from Celtic_Druid)
- Updated ffdshow to revision 479
- Updated DivX decoder to version 6.2.5.34
- If you have stability issues with the DivX decoder, then don't install it or disable it via the Codec Tweak Tool and use ffdshow instead.
- Updated DivX encoder to version 6.4.0.51
- Updated AC3Filter to version 1.11
- Updated x264 VFW to rev. 578
- Updated Haali Media Splitter to version 1.6.338.23
- Updated Cyberlink MPEG decoder to version 6.0.0.3402
- Updated Cyberlink MPEG demuxer to version 1.0.0.4528
- Updated FLAC to version 0.73.1936
- Updated LAME MP3 ACM to version 3.97
- Updated LameDropXPd to version 3.97
- Updated LAME CLI to version 3.97
- Updated OggDropXPd to version 1.8.9 aoTuVb5
- Updated DirectVobSub. This should fix a (rare) problem with green lines on some divx files.
- Updated GSpot to version 2.60 beta 2
- Added .asf file association option
- MPC will now play 3GP files using DirectShow filters (MP4 splitter + ffdshow) instead of QuickTime.
- Added option to create a System Restore Point at start of installation.
- Improved compatibility with Windows Vista
Download
感謝提醒更新~~~
下載去~
更新去....
謝謝分享
收下了
感謝大大的分享喔
阿哩阿多^^"
有下有回,相當好用的軟體,多謝提供!~
喔喔!!又出新版本囉
下載更新去
多謝大大熱情分享
電腦從灌剛好可以更新一下...感謝分享!!!
