【更新】Alcohol 120% 1.9.6.4629
Ethan.CPA
台北
Change Log:
- NEW SPTD driver version 1.35.
- NEW Full Windows Vista RC2 (Build 5744) compatibility 32Bit and 64Bit editions.
- NEW RMPS V2, a totally new generation of our RMPS feature
- NEW Option to install Alcohol with or without Virtual drive function.
- NEW EWSS (Enhanced Weak Sector Scanner).
- NEW. Shell Context Menu support in all x64 platforms. (XP, Windows Server 2003 and Vista RC2).
- UPDATE Shell Context Menu to sort drive list by drive letter, and single menu item when only one virtual drive is installed.
- UPDATE Alcohols Sector Viewer in CD/DVD Manager, now provides more detailed information for DVD.
- UPDATE Alcohol data type profiles.
- UPDATE "Ignore Media Type" Function; to include DVD media.
- UPDATE. Alcohols help files
- UPDATE Language Translations
- UPDATE Alcohols Virtual Drive engine.
- UPDATE Alcohols write engine
- UPDATE Alcohols read engine
- FIX Missing installed device drivers list in Alcohols system report for X64 platforms.
- FIX "Invalid User Buffer." Error, that affected some systems.
- FIX. Minor bugs reported by users.
- FIX Problem related to U3 USB if RMPS function was active
- FIX Problem related to Acronis True Image issue
- FIX Problem related to Mac Drive issue
Download
又更新了哦!最近酒精更新速度還真快!
謝謝kofung大提供更新訊息!
有下有回~
感恩拉!
多謝分享哦;face0;
不知道更新了些什麼 我是英文白癡 看不懂;oq;
用用看再說囉
Thank you so much.
前一版本Alcohol 120% 1.9.5.4521
裝好後,就會自行啟用一台虛擬光碟
並且可以直接點選映像檔,按右鍵掛載或是卸載
此版Alcohol 120% 1.9.6.4629
安裝時可以選擇是否啟用盤擬光碟
啟用後確不能按右鍵 掛、卸載
一定要開啟酒精程式後才能掛載映像檔
請問有使用的大大,知道這是怎麼回事嗎?
還是本來版本就是這樣?
有下載,要回應,感謝樓主分享
