WinX DVD Ripper Platinum v5.11.2
Info:
WinX DVD Ripper Platinum v5.11.2 | 8.6 MB
This DVD ripper software supports multi-core CPU and is fully compatible with Windows 7. We promise WinX DVD Ripper Platinum is the fastest DVD ripping solution in the market. Besides converting DVD to regular video formats, 1:1 DVD copy enables you to backup your DVD with original video, audio and subtitles within only 5 minutes (the processing time also depends on your CPU and DVD driver speed). WinX DVD Ripper Platinum fully supports normal DVDs, CSS protected DVDs, Sony ArccOS DVDs and all region 1-6 DVDs. Moreover, we are so proud to tell you that WinX DVD Ripper Platinum is the unique DVD ripping program which supports decrypting DVDs with the latest copy protection technology such as Transformers 2, Star Trek 2009, The Dark Knight, UP, WALL-E, The Proposal, District 9.
Features:
* 1:1 DVD Copy without Quality Loss
* Decrypt & copy DVD to PC with 100% original video, audio and subtitles within only 5 minutes
* If your original DVDs audio is out of sync with movie, the Intelligent A/V Synchronizer can help you solve the problem
* To avoid any kind of problems during conversion process we offer you safe mode which can skip the problems and finish the whole conversion process more smoothly
* Enable to change interlaced scanning DVD movie to progressive scanning, make converted video with clearer image
* Multi-core CPU supported, which makes your conversion process much faster Batch rename all clips easily with “Renaming Template”
Info:
Features:
代碼:
Download Link:
http://rapidshare-7.blogspot.com/2010/05/winxxx.html
No Pass
