Error Repair Professional 4.1.1
代碼:
Info:
Keep your PC operating smoothly by using Error Repair Professional to scan, identify, clean and repair errors in your PC with a single click. With a few easy steps, it will scan your entire registry for any invalid entries and provides a list of the registry errors found. You can then choose to selectively clean each item or automatically repair them all. Windows Registry is the nerve center of your PC and problems with the Windows Registry are a common cause of Windows crashes and error messages. These problems can occur for many reasons including uninstalling software with poor un-installation routines, by missing or corrupt hardware drivers, improperly deleting files and orphaned startup programs. By using Error Repair Professional regularly to fix error in Windows registry, your system should not only be more stable but it will also help Windows boot faster.
The Windows registry is a database which stores settings and options for the operating system for Microsoft Windows 32-bit versions, 64-bit versions. It contains information and settings for all the hardware, software, users, and preferences of the PC. Whenever a user makes changes to "Control Panel" settings, or file associations, system policies, or installed software, the changes are reflected and stored in the registry.
代碼:
Download Link: (Rapidshare)
http://rapidshare-is.blogspot.com/2010/01/part1_7792.html
No Pass
