[已售出]EnzoTech-Ultra-X CPU散熱器
Day_knight
1.品名 : EnzoTech-Ultra-X CPU散熱器
2.數量 : 1組
3.品相及保固 : 96/9日購於光華,除使用散熱風扇及LGA775配件外,完整配件及AS5均未用,原廠保固中,已清除使用的灰塵
4.售價 : 1,000 (不含運費)
5.地點 : 新竹及台北市 (自取) 全省(郵寄)
6.交易方式: 自取 郵寄
因BT目前傾向節能使用,不再需要如此散熱佳的風扇,故售出.
產品完整介紹及測試報告,請參考C大之前的測試
http://forum.coolaler.com/showthread.php?t=148131
產品特色
Compatible with all single and dual-core CPUs for Intel® Socket 775 and AMD™ Sockets K8/AM2/754/939/940
The base of the Heat Sink is machined to 0.0003 per inch run-out, which optimizes surface contact and maximizes thermal conductivity performance
Four 8 mm heat pipes guarantee the CPU will always run smooth and at optimum efficiency
The large 120 mm fan provides extreme volume of airflow which will keep your Northbridge chipset cool at the same time
Artic Silver®5 Thermal Grease and Adjustable fan speed control included
產品規格
Dimension (L x W x H) 148x148x118mm
Total Weight 835g
Fan
Delta Fan AFB1212H-F00
Dimension (L x W x H) 120x120x25.4mm
Speed 1200~2500 RPM
Noise 24.5~38.5 dB-A
Air Flow 35.8~82.67 CFM
Voltage 12VDC . 0.35A
Connector Molex 2695- 3 Wire
Bearing Type 2-Ball
台北周一至周五可自取,新竹限假日自取,其餘地區請自加運費.
意者請留聯絡電話至email或PM將會主動與您聯絡.謝謝!!
email: lioyang@yahoo.com.tw
