Emsisoft Decrypter for ApocalypseVM 是 Emsisoft 設計用來將 ApocalypseVM 勒索病毒所加密檔案解密的軟體,勒索病毒 ApocalypseVM 會將您的檔案加密並更名為 *.encrypted,而每個加密檔會包含名為 *.How_To_Decrypt.txt 或 *.How_To_Get_Back.txt 的勒索信,而勒索信會要求您與 "decryptionservice@inbox.ru" 聯繫並包含個人的識別碼。要使用此解密軟體將需要至少 4096 位元組大小的加密檔案以及其未加密的版本。要啟動 ApocalypseVM 解密軟體必須同時選擇加密和未加密的檔案並將它們拖放到解密
軟體的可執行檔上。
【軟體名稱】:Emsisoft Decrypter for ApocalypseVM 1.0.0.31 - 勒索病毒 ApocalypseVM 解密軟體
【軟體大小】:999 KB
【作業系統】:Windows All
【官方網站】:https://decrypter.emsisoft.com/apocalypsevm
【語言種類】:英文
Use this decrypter if your files have been encrypted and renamed to *.encrypted with ransom notes named *.How_To_Decrypt.txt or *.How_To_Get_Back.txt created for each encrypted file. The ransom note asks you to contact "decryptionservice@inbox.ru" and contains a personal ID. To use the decrypter you will require an encrypted file of at least 4096 bytes in size as well as its unencrypted version. To start the decrypter select both the encrypted and unencrypted file and drag and drop them onto the decrypter executable.
載點:
下載連結→ [按此下載]
軟體的可執行檔上。
【軟體大小】:999 KB
【作業系統】:Windows All
【語言種類】:英文
載點:
下載連結→ [按此下載]
