DVDFab Platinum v6.0.6.0 - Final_無損複製DVD電影_便攜式
  • 主題發起人 主題發起人 le2712
le2712
【軟體名稱】: DVDFab Platinum v6.0.6.0 - Final_便攜式
【軟體語言】:多國語言
【軟體分類】:燒錄程式
【軟體性質】:共享
【檔案大小】:13.9 MB
【放置空間】:RapidShare/depositfiles
【軟體附件】:已註冊
【軟體介紹】:
DVDFab是一款輕鬆製作完美DVD備份的工具.可以實現DVD到DVD的複製,在複製的同時去掉所有的保護機制,可保留原有的選單、片花和其他功能,可複製到一碟或多碟等.
[table=98%][tr][td][table=98%][tr][td=1,2,120] [img=120,120]http://i605.photobucket.com/albums/tt131/le2748/2nbvqq9.png[/img][/td][td]-可以幫助你輕鬆製作完美品質的 DVD影碟備份的光碟複製工具!
-無損複製DVD電影、-可複製NTSC或PAL制式DVD、
-可只複製電影部分,不包括不需要的音頻和字幕、
-可燒錄到DVD-R/RW和DVD+R/RW、
-移除所有的DVD保護方式、
-備份多個光碟、
-恢復損壞的碟片中的數據、
-重寫和核心引擎以支援幾乎所有的DVD!
[/td][/tr][/table][/td] [/tr][/table]
Changes in DVDFab 6.0.6.0 (September 4, 2009):
* New: Updated VSO burning engine, now it works correctly on Windows 7 64-bit.
* New: Updated language files.
DVDFab "DVD to DVD":
* New: "PathPlayer" is set to "Always enable PathPlayer" by default now, since it's needed for new protections and for Navigation options.
* New: "Writable Media (DVD-9) Size" is set to 8100 MB by default now.
* Fix: A PathPlayer problem that playable content be removed in certain cases.
DVDFab "Blu-ray to Blu-ray":
* New: AACS MKB14 is fully supported now. Note: since AACS MKB14 issue, BD+ support was delayed and will be available in September.
* Fix: A silent exit problem when opening Blu-ray with lots of m2ts files.
* Fix: Output cannot be played if there are .jar files in BDMV\JAR folder, in certain cases.
DVDFab "DVD to Mobile":
* New: UI layout is redesigned, and now it just need one click to convert.
* New: Added "Mobile Task Queue" as a standalone window.
* New: For now each device can have an entry on navigation bar or menu, so "Generic" will not contain the user-created devices anymore. DVDFab will move user-created devices to navigation bar or menu automatically.
* Fix: A crash problem when converting to NDS in certain cases.
DVDFab "File to Mobile":
Homepage - http://www.dvdfab.com/dvd-fab-platinum.htm
確保下載的軟體能正常使用,請使用
WinRAR 3.90 Final 版本解壓
謝謝le2712大的提供 ^^
