Core Temp 0.99.6/32&64bit
flyht
- Add: Support for new and upcoming Intel and AMD processors.
- Add: Better recognition of AMD dual/tri core unlocked CPUs.
- Add: Optional 24 hour display on G15 LCD.
- Fix: Platform field blank for newer AMD CPUs.
- Fix: Some K8 CPUs were unknown or recognized incorrectly.
- Fix: Overheat protection "Activate at specified temperature" problems were fixed.
- Fix: Overheat detection does not show a Balloon Tip when user specified temperature value is set.
- Fix: Temperature displays a negative value when core temperature reaches over TjMax (Intel).
- Fix: Intel W3500 series Xeons recognized with Core i7 model numbers (ie W3520 shown as Xeon 920)
- Fix: In certain cases Core 2 Duo T5500 was recognized as a T5450.
- Fix: G15 LCD display is no longer always-on-top after coming out of sleep or hibernation.
- Fix: G15 won't display 0.0000v in case VID readings are not supported by the CPU.
- Fix: In some cases, at Windows startup systemtray icons would not appear.
- Change: Windows XP SP2 or higher is now required.
- Change: Completely new processor frequency detection algorithm. (for Core 2 generation and newer only)
- Change: Remove "APICID" from main window as it has very little use.
Core Temp 0.99.6 (32-bit)
Core Temp 0.99.6 (64-bit)
josephchou2
這麼快就有更新了
感謝大大分享!
triplestars3
感謝大大分享
字面上是比較能夠辨認amd開核溫度?
小男孩
感謝大大分享
字面上是比較能夠辨認amd開核溫度?
:rolleyes:︰「剛剛試了一下好像還不行,請看下圖︰
triplestars3
可能是比較能'辨識'開核的...
這樣吧...?
Happypc
********.com低階會員
收下來更新嘍 !! :rolleyes:
感謝樓主大的分享! ;ranger;
viragegto
新版的CPU溫度監控程式
很好用的軟體說
謝謝分享
TAS
"人"生淫家...
終於更新了...
不過還是要加點油...;face12;
Godzillas
0.99.6版的不知新增什麼新功能,快下來 試試
