Cooler Master - AQUAGATE Viva
World’s First VGA Liquid Cooling System converted to CPU Application
CPU Liquid Cooling System
attachment.php
AQUAGATE DuoViva
attachment.php
attachment.php
How can Cooler Master expand your imagination? In continuation with our innovative all-in-one liquid cooling design which dramatically simplified the installation process and provided excellent cooling, Cooler Master is introducing its newest VGA liquid cooling system – AQUAGATE Viva. This is the world’s first VGA liquid cooling system that can be conveniently transformed into a CPU liquid cooling system. The universal retention plate supports both nVIDIA/ATI VGA cards as well as the universal fastener for K8/P4/LGA775 CPUs. In addition, AQUAGATE DuoViva comes with 2 water blocks to support SLI and CrossFire.
With a copper-based water block, AQUAGATE Viva can achieve excellent heat dissipation. The intelligent thermistor fan unit will automatically adjust fan speed for ultimate cooling performance. When AQUAGATE Viva is used as a CPU liquid cooling system, the fan bracket unit allows you to install the fan directly on top of the water block module. Thus, AQUAGATE Viva achieves maximum heat dissipation for the CPU and its surrounding components.
Not only does it provide exceptional cooling, the silent operation also surpasses expectations. The ceramics bearing pump brings longer life expectancy and lowers the noise level. To maximize flexibility with space limitation, the radiator with its two 70mm thermal sensor fans can be installed either on PCI slots, side panel, or HDD Rack. Furthermore, the special alarm feature is incorporated to minimize system malfunctioning damages. The alarm will be automatically triggered whenever there is any abnormal operation. Such alarm system keeps you on top of any surprises.
the cpu waterblock seems a little.....ugly;x;
Keep in mind...CoolerMaster mostly OEM their products anyway...:D
