Cisco Packet Tracer 5.2.1.8 & Tutorials
Info:
Packet Tracer Version 5.2.1.8 Software Downloads
Packet Tracer version 5.2.1.8 is a maintenance release that fixes a software issue in version 5.2.1 that causes the Check Results button to be incorrectly disabled in certain situations. You should upgrade to this version if you are currently using version 5.2.1 and expereince the issue. Previous versions of Packet Tracer are not affected.
Packet Tracer supports activities authored in Packet Tracer 4.0, 4.1, 4.11, 5.0, 5.1, 5.2 and 5.2.1. Packet Tracer 5.2.1 has been replaced by Packet Tracer 5.2.1.8 and is no longer available for download. Please note that the last two courses of the CCNA Discovery and CCNA Exploration curricula require Packet Tracer version 4.11 at a minimum, CCNA Security requires version 5.2 at a minimum, and the beta Packet Tracer Skills Based Assessments require version 5.2.1 at a minimum. The curricula are fully compatible with Packet Tracer 5.2.1.8
You can download both the Packet Tracer application and tutorial files in one download package. However, due to the large file size it is faster to download the application by itself, if that is all you need. Choose the download option appropriate for your needs.
Download Link:
Info:
Download Link:
代碼:
Hotfile
http://rapidshare-8.blogspot.com/2010/03/part1_4176.html
Pass: hunted
Rapidshare
http://rapidshare-8.blogspot.com/2010/03/part1_3516.html
Pass: hunted
