Software highlights:
-) Support for ATI Control Center
-) Support for TV Out and displays with profiles
-) Options to change Theater mode together with TV Out
-) Overclocking with templates including FAN Control
-) Automatic overclocking when application required 3D mode
-) Temperature monitoring
-) Artifact Tester with ability to find maximum stable clocks for GPU and Memory.
-) Game profiles with desktop shortcut creation.
-) Direct3D settings with templates, GUI form and tray popup menu
-) OpenGL settings with templates, GUI form and tray popup menu
-) Hardware low level color correction
-) Hardware tweaks. Setting PCI latency timer
-) Radeon Information Show information about memory type, active rendering pipe lines and more
-) System wide Hot Keys. (Load profiles any profiles/work with colors/run any application)
-) Refresh Lock system with ability to set separate refresh rates for each resolution.
-) Tweak for overriding Pixel and Vertex Shaders
-) Speed improvement tweaks for Anisotropic/Trilinear Filtering. Support for Catalyst A.I.
-) Support for system options, VPU Recover, DMA Copy and so on
-) Support Display Rotation.
-) Support for MMC applications
-) Support for HYDRAVISION applications
-) Monitoring Graphs. (GPU/Env temperature. GPU/Mem speed, Main CPU Usage).
-) A lot of useful things. Like Save/Restore Desktop icon positions and more
Audio Recorder
-) Screenshots system
-) Powerful Plug-Ins support. (API for VC++/Delphi included)
-) PCI Register Set. Allow to program any registers in any PCI device at start up time. For advanced users only!
-) Source code for plugins as examples.
-) Supported OS: Windows 2000, Windows XP, Windows 2003
Windows 9x/ME is not supported!
Download
