Last month, I toyed with the APU processors, namely AMD A10-5800K. While tuning the APU is not paid in fiber (since it will be at an unnamed site article), I have prepared for you at least demonstration performance GPU after overclocking. I think that you play nicely with a lower model A10-5600K, which has a slightly weaker video card and on how badly will not be the weakest integrated Radeon HD 7480D. He, however, I would recommend for 1280x1024 resolution or other offshoots 1280x XXX.
Yet it has a base power of HD 7660D in the base more than decent performance and power are often close to popular Geoforce GTX/9800GT 8800. It should be noted in the same breath that the integrated graphics accelerator advantage of frequency memory and make less than 1600 MHz for this set is bare ignorance. Then preferably native 1866 MHz or 2133 MHz XMP.
GPU overclocking is through the BIOS, unlocked APU advantage is the possibility to have a gf card unlocked upwards. OC potential reader is approximately 300 MHz iGPU for all cards in the Trinity APU. Random graph from one review I will now, Unreal Tournament 3 still looks fairly well and play well for full details with integrated graphics just two years ago was unthinkable ...
But back to the original consideration. If bduete clocked AMD Trinity and its iGPU, I recommend:
- unlocked CPU + average or good record and a good record (about 1800-3100 CZK) - locked CPU + high quality board (Asus F2A85-M Pro)
-at least 1866 MHz memory and try to overclock it further, preferring to hold the command rate on the value of 2T and try to reach higher memory frequencies
GPU-OC at around 1 GHz, this velvet usually achieved easily, do not forget to increase at a higher voltage APUNB, around 1.35-1.4V is completely safe
-if you also clocked processor, then count with a limit around 4300 MHz (BOX cooler) to 4,600 MHz (decent air cooler). With a bit of luck (a little big), you have a very good processor that you can say up to 4800 MHz.
And games? From a practical test, if only in a few games and utilities can be concluded that the games a few years old, you can really play at a high resolution of 1920x1080 with maximum detail (but mostly without AA / AF). In modern titles you can find two options, some still pull away at 1920x1080 and decent detail, while others such as AVP you lose detail, off AA / AF and Holt tesalaci or reduce the resolution up to 1680x1050. Even so, the gaming experience is worth it. Even after Battlefiled 3, OC run-up on average 30 + FPS at 1680x1050, the details are brought to their low. The game still looked very good.
Finally, with a test kit I made a few videos. Of course in addition to AMD A10-5800K was necessary decent cooler Noctua NHD14 that all safely uchladil, motherboard Asus F2A85-V Pro, and megalomaniacal AX1200W source, which is too much for such an assembly Oversized ....
[video=youtube;0WS8vEqnvzw]http://www.youtube.com/watch?v=0WS8vEqnvzw[/video]
[video=youtube;g7NmydOzzuc]http://www.youtube.com/watch?v=g7NmydOzzuc[/video]
[video=youtube;LQSG_MLXCzM]http://www.youtube.com/watch?v=LQSG_MLXCzM[/video]
[video]http:thumb:://www.youtube.com/watch?v=g9xCuHFGCzM[/video]
The video quality as my camera and dark room, where the sun shines too: (.
