AI Turing[Manual]
CPU Frequency[500]
DRAM Frequency[DDR2-1000MHz]
PCI Express Frequency[100]
PCI Clock Frequency[33.33MHz]
Spread Specttrum[Disabled]
Over Voltage
CPU VCore Voltage [1.4V]
FSB Termination Voltage [1.4V]
NB VCore [1.45V]
Menory Voltage [2.3V]
DDRII Cannel A REF Voltage [Auto]
DDRII Cannel B REF Voltage [Auto]
DDRII Controller REF Voltage [DDRII REF+10mv]
SB VCore(STAT,PCIE) [Auto]
SB Chipset Voltage [Auto]
_____________________________________________________
ASUS C.G.I [Auto]
Static Read Control [Auto]
Configure DRAM Timing by SPD[Disabled]
DRAM CAS# Latency [4]
DRAM RAS# to CAS# Delay[4 DRAM Clocks]
DRAM Precharge [4 DRAM Clocks]
DRAM Activate to Precha [12 DRAM Clocks]
DRAM Write Recovery Time[4 DRAM Clocks]
DRAM TRFC [30 DRAM Clocks]
DRAM TRRD [10]
Rank Write to Read Delay [10]
Rank to Precharge Delay [10]
Write to Precharge Delay [10]
________________________________________________________
Advanced
Modify Ratio Support [Enabled]
Ratio CMOS Setting: [6]
C1E Support [Disabled]
Max CPUID Value Limit: [Disabled]
Vanderpool Technology: [Disabled]
CPU TM function: [Disabled]
Execute Disable Bit [Disabled]
PECI [Disabled]
以上是我的建議,至於CPU和RAM電壓一你的體質做上下修正,看是要加壓還是要降押都可以!;em28;
不過為何不用7倍頻上3.5G呢?
