【軟體名稱】:Aone Ultra Video Converter 4.4.1021
【軟體語言】:多國語言
【軟體分類】:影音剪輯
【軟體性質】:RAR
【檔案大小】:8.25 MB
【放置空間】:nakido/ RapidShare
【解壓密碼】:no
【軟體介紹】:
Ultra Video Converter 是一款功能強大的視訊轉換、合併和分割工具,Ultra Video Converter 支援 AVI, Divx, XviD,MPEG1, MPEG2, VCD, SVCD, DVD, WMV, ASF 等格式。
Key Features:
• Video source supports AVI, DivX, XviD, MPEG, DAT, WMV, ASF, RM, RMVB, MOV, QT, MP4, M4V, 3GP, FLV, MKV etc.
• Supports all video files to AVI, DivX, Xvid
• Supports all video files to MPEG1, MPEG2
• Supports all video files to VCD, SVCD, DVD compatible MPEG formats
• Supports all video files to VCD SVCD image (*.BIN, *.CUE) and DVD-Video files (*.IFO,*.VOB,*.BUP)
• Supports all video files to WMV, ASF
• Supports all video files to MP4, 3GP
• All encoders/codec are built-in and any supported conversion can be done once you downloading the software
• Batch files conversion
• Output size adjustment, output quality adjustment
• Cut unwanted parts by specifing start time and end time
• NTSC/PAL setting options for DVD, VCD, SVCD exporting
• Support "Drag and Drop" from Windows Explorer
• Custom define the output audio volume.
• Add letterbox to keep the original aspect ratio
• Support large video file, even large then 2GB
• Fast conversion speeds and high quality
• Simple GUI and very EASY to use
Aone Ultra Video Converter 4.4.0827
確保下載的軟體能正常使用,請使用
