AMD 最新修定 K10.5「Hydra」挑戰 Intel Nehalem
  • 主題發起人 主題發起人 x3dfx
x3dfx
www.xfastest.com
消息來源︰Fudzilla
AMD 最新修定版本 K10.5 Rev. D
45nm SOI、核心︰Hydra
將在 2009 年 Q1 開始試驗生產
L2 追加為 1MB
其餘詳全文
Fudzilla - AMD K10.5 Hydra to challenge Nehalem
After Deneb and Propus 45nm K10.5 Quad-cores AMD plans to change the process and improve the existing K10.5 cores. The new process is called 45nm K10.5 Rev. D and it will bring high K to 45nm SOI cores. K10.5 Rev. C is the 45nm SOI process that AMD plans to use for Deneb and Propus 45nm cores. AMD calls Rev D cores Hydra and these are the chips that will really go against Nehalem.
The test production of these rather interesting cores will start in Q1 2009, but we expect to see the production cores by the middle of 2009 or a bit later.
The new K10.5 Rev. D supports 1MB L2 per core, which is twice as much as in current K10 CPUs and 6MB L3 cache memory. The most important feature is that it will be able to get you eight cores and we believe this is eight-core native design and not MCM (Multi Chip Module), as many have suggested before. This confirms our earlier story that AMD’s eight cores are native and you can read it here.
The new chip should be able to hit clocks in excess of 3GHz but we will hold our breath until we see it. This does look positive for AMD, but it still means that Nehalem will probably be the market leader for at least six to nine months before it gets a real competitor.
10.5 ...
連名稱都開始有小數點了
10.5
K10的加強版嗎?
如果行得通
那難保K11是L2   1mb以上的
那也許會有一點點看頭
如果外頻可以333以上
那才有看頭吧
L2追加為1M,可要等到什麼時候才能追
到 INTEL呢?
AMD還真是小氣.L2直接加到6M吧.這樣比較有看頭
這新聞的重點應該是說K10與K10.5的最大差異是K10使用Ultra-low-K, 而K10.5使用High-K, 藉此降低閘極的漏電流, 降低Phenom的功率. 功率降低之後, 時脈就會有機會提高.
等到產品出來 在看看有沒有看頭吧
