【軟體名稱】:Allok Video to DVD Burner v2.5.1117 繁中免安裝版
【軟體語言】:繁體中文
【軟體分類】:媒體燒錄
【檔案大小】:7.7 MB
【檔案類型】:7z壓縮檔【WinRAR v3.90 繁體中文正式版 (32bit + 64bit + Protable)】
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.alloksoft.com/video_to_dvd_burner.htm
Allok 出品的視頻轉換/燒錄為DVD的強力工具,可將多種主流視頻格式高速度轉換和/或高品質燒錄於DVD光碟上。
Allok Video to DVD Burner 支援TV制式調整(NTSC/PAL),縱橫比調整(16:9寬屏/4:3標準),音頻增益,自動章節分割/手動視頻分割,以及輸入外掛字幕等附加功能(方便那些不知如何將字幕嵌入視頻中的使用者),非常好用!
此軟體內置了燒錄引擎,這樣無需第三方軟體即可實現DVD光碟的燒錄,以便在家庭影碟機上觀賞。
Key Features:
· Burn AVI, DivX ,Xvid, MPEG, VCD, WMV, ASF, MOV ,RM, RMVB, 3GP, 3GP2, MP4, M4V, MPEG4 to DVDs.
· Saved output DVD movies onto hard disk.
· Burn source saved DVD movies from hard disk to DVD Disc.
· Output size adjustment, output quality adjustment.
· Cut unwanted parts by specifing start time and end time.
· Add subtitile onto the output video.
· Advanced dolby digital audio,give your movie theater quality sound.
· All encoders/codec are built-in and any supported conversion can be done once you downloading the software.
· Supported device types include DVD-R, DVD+R, DVD-RW, DVD+RW.
· NTSC/PAL setting options for DVD, VCD, SVCD exporting.
· Support "Drag and Drop" from Windows Explorer.
· Custom define the output audio volume.
· Add letterbox to keep the original aspect ratio.
· Support large video file, even large then 2GB.
· Fast conversion speeds and high quality.
· Simple GUI and very EASY to use.
如果你覺得本軟體好用的話請點一下右下角的↘![]()
感謝支持!也別忘了支持正版唷!
