Advanced Defrag 4.5.0 datecode 20100426
Info:
What is Advanced Defrag? Advanced Defrag is an award-wining defrag program which is designed to help you handle the above mentioned problems and keep your computer running like new. program applies advanced defragment arithmetic which enables you to completely and fast analyze & defrag all the fragment found in your computer hard drive, effectively maximum the system performance and improve your working efficiency with the computer.
Features:
- Speedy analyze and defrag completely & thoroughly.
- Individual file analyze & defrag support.
- File crash support.
- Scheduled task and auto-update support .
- Detailed analyze and defrag web-report.
- Mobile device support & Windows OSs support.
- Advanced multithreading, sharing technology.
- Portable, succinct and easy to use.
- File filtration setting support.
Info:
Features:
代碼:
Download Link:
http://hotfile-4.blogspot.com/2010/05/advanced-defrag.html
No Pass
