7-Zip 9.09 Beta/ 7-Zip 4.65_現今最高解壓縮比壓縮軟體
  • 主題發起人 主題發起人 le2712
le2712
【軟體名稱】:7-Zip 9.09 Beta/ 7-Zip 4.65
【軟體語言】:多國語言
【軟體分類】:壓縮合併
【軟體格式】:zip
【檔案大小】:1.2 MB
【放置空間】:depositfiles/ nakido
【解壓密碼】:no
【軟體介紹】:
7-Zip是一款號稱有著現今最高壓縮比的壓縮軟體,它不僅支援獨有的 7z 檔案格式,而且還支援各種其它壓縮檔案格式,其中包括 ZIP, RAR, CAB, GZIP, BZIP2和 TAR 等等。此軟體壓縮的壓縮比要比普通 ZIP 檔案高 30-50% ,因此,它可以把 Zip 格式的檔案再壓縮 2-10% 。這是7-Zip多國語言版,支援繁簡體中文等。
7-Zip is a file archiver with a high compression ratio. The program supports 7z, ZIP, RAR, CAB, GZIP, BZIP2, and TAR formats. Compression ratio in the new 7z format is 30-50% better than ratio in ZIP format. It also compresses to ZIP 2-10% better than PKZip and WinZip. It has an additional powerful command line version and FAR Manager support.
Changes in 7-Zip 9.09 ( 2009-12-12):
* 7-Zip now can unpack Apple Partition Map (APM) disk images.
* Speed optimizations in AES code for Intel's 32nm CPUs.
* Speed optimizations in CRC calculation code for Intel's Atom CPUs.
* Some bugs were fixed.
* VHD support was improved.
Don't use this alpha version for important data. Call "Test" command after each compressing operation.
Homepage - http://www.7-zip.org
7-Zip 9.09 - Beta (32-bit)
7-Zip 4.65 - Final (32-bit)_免安裝
