【檔案名稱】:O&O Products Pro Editions x86/64 系統維護工具包
【軟體語言】:英文
【軟體類型】:系統維護
【檔案格式】:RAR
【檔案大小】:416MB
【壓縮密碼】:無
【上傳空間】:Filepost/Wupload/Easy Share/Filesonic/FreakShare
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
O&O Defrag 15 Professional Edition
Maximum Performance for your PC
Do not wait too long! If you work on computers a lot, then slow system and program starts, endless rendering and
memory processes, or even system crashes when playing can quickly ruin your enjoyment. Defragmenting your PC can
hugely accelerate the speed you can work on your PC. When you defragment, those files fragmented across the hard disk
are logically rearranged so that files can be quickly recognized and processed by the hardware. Performance gains of up
to 100% are not uncommon!
In the new version of O&O Defrag, you can now see what the program does for your system thanks to graphics and
statistics, which give you a before-and-after Defrag contrast!
System requirements:
Minimum requirement of each operating system
512 MB RAM (1 GB RAM recommended)
50 MB free hard disk space
Windows ™ XP, Vista ®, Windows 7 (32 bit/64 bit)
O&O DiskImage 6 Professional Edition
Maximum Data Security!
Here’s the safest and easiest way to avoid losing important data! O&O DiskImage lets you backup an entire computer
or individual drives and files whenever you want – even while the computer’s being used. Never again will you have to
worry about lost data: The backups you make can be restored with just a few clicks of the mouse – even if Windows is
unable to start!
O&O DiskImage combines features for both the home user and the IT expert in one single product. A whole range of
default and user-defined options lets you create the backup scenario that suits you best. A Start CD containing additional
system recovery tools will let you quickly restore important data -even when the images were created with older versions
of the product.
Minimum requirements of the respective operating system
At least 1 GB RAM recommended
30 MB free hard disk memory
32/64-bit support
Windows® 7, Vista® and XP (all Editions)
O&O DiskRecovery 7 Tech Edition Professional
O&O DiskRecovery Tech Edition is authorized for commercial use on an unlimited number of computers. For the one-time
cost of a license, self-employed administrators or service technicians can recover data on any computer where the
product is supported. When needed, O&O DiskRecovery can also be started directly from an external disk (e.g., USB stick)
which means there’s no time-consuming installation. Its unique combination of three different scanning and recovery
algorithms allows O&O DiskRecovery to track down any data than can be recovered. O&O DiskRecovery can even find
and recover data in the most extreme situations, such as with already formatted or destroyed file systems.
One important special feature of O&O DiskRecovery 7 Tech Edition is an option for creating a bootable medium based on
Windows PE 3.0. Along with O&O DiskRecovery, this bootable medium contains various O&O system recovery programs
that provide access to the Windows Registry and stored files.
System requirements
The minimum requirements of the respective operating system must be met
20 MB free hard disk space
32/64-bit support
from Windows® 2000 to Windows® Server 2008 R2 (all Editions)
O&O SafeErase 5 Professional Edition
No chance for data spies
What happens to your old computer or hard drive when you get a new one? Do you return your company’s computers
to the leasing company or even sell your laptop on the Internet? In that case, there are good chances that complete
strangers might gain access to your private pictures, letters or business secrets.
The fact of the matter is, data deleted using Windows is not really deleted! Unauthorized persons can still recover your
digital pictures as well as your personal and company data, even if you formatted the disk beforehand. Surfing the
Internet leaves its mark as well: On the basis of the Internet browsing history stored on your computer, it’s easy to
generate an accurate profile of your preferences, see the pages you’ve visited, and even scan the files you’ve
downloaded. Protect yourself by using O&O SafeErase to permanently delete all data from your hard disk using
scientifically recognized methods.
The analysis tool of O&O SafeErase 5 lets you track down and immediately remove all the files that are a security risk on
your computer. What’s more, data from SSDs can now be permanently deleted as well using methods that go sparingly
on resources. Never take chances with your data: SafeErase it!
System requirements
32/64-bit support
O&O CleverCache 7 Professional Edition
Even with the latest hardware, the processing of digital pictures, videos, games and constant server loads can often lead
to longer answering times or “frozen” programs. In fact, it’s often not the lack of main memory capacity that’s at
fault, but the file cache management of your Windows operating system. O&O CleverCache makes sure that the file
cache is reset while the computer’s running: something that otherwise usually requires a restart of the computer. O&O
CleverCache will let you continuously maintain maximum levels of performance on your computer – no new start
required, and with just a few clicks of your mouse.
O&O CleverCache prevents those infamous program and application “freezes” where usually only closing the program
with the Windows Task Manager can help. Simply install O&O CleverCache and let it take care of your computer or
servers memory management.
System Requirements:
50 MB free disk space
32-bit/64-bit support
O&O DriveLED 4 Professional Edition
An early-warning system for hard disk crashes
When is it the right time for giving your computer a rest? When it’s too hot? Overloaded? Vital components are on the
verge of breaking down? No other single part of the modern computer system is more susceptible to malfunction than
the hard disk. In fact, such a malfunction can come without warning and often strikes while the computer’s being used.
O&O DriveLED, working quietly in the background, permanently monitors the status of your hard disks and warns you of
any impending problems. With it, you’ll always have time to backup your data and so avoid losing any of it when
exchanging a hard disk. This is time a sudden crash will never give you.
32/64-bit support
15 MB free hard disk space
Windows® 7, Vista®, XP (all Editions)
O&O PartitionManager 3 Professional Edition
There’s nothing worse than watching your computer gain more and more data, become more disorganized, and still
having the feeling there’s not a lot you can do. With O&O PartitionManager, you can clean up, get organized and
structure your machine how you want it, saving you both time and money.
By dividing your hard disks into partitions, you can separate private and professional documents, for instance. We
recommend two partitions: one system partition with all Windows and software files, and a data partition with all your
personal or professional files such as photos, videos or Office documents. This setup also makes data backups and
restorations easier. The Start CD from O&O PartitionManager is based on Windows PE, and lets you extend, shrink or
move system partitions – depending on their data volume and file system – very conveniently and easily.
1 GB RAM recommended (for Start CD)
32 Bit/64 Bit support
Windows® 7, Vista®, XP and 2000 Pro (all Editions)
O&O DiskStat 2 Professional Edition
Generally speaking, there are two distinct types of people: some simply cannot throw things away, whereas others have
no problem getting rid of stuff they don’t need and that is just taking up space. Only one of these approaches can be
applied to modern computers – no prizes for guessing which one! And that is where O&O DiskStat comes in.
Regardless of whether at home or in a company network, ever-increasing amounts of data can severely slow down the
time needed for accessing files and making backups. You’ll be amazed at how much disk space you can win back simply
by getting rid of the ballast. O&O DiskStat 2 allows you to analyze used space on your hard disk with the help of
interactive graphics. Once identified, you can get rid of the space-wasters on your disks, gaining space for new programs
and data, and saving money you might have spent on a new disk.
Minimum requirements of respective operating system
10 MB free hard disk space
O&O MediaRecovery 6
Besides the continuous maintenance and enhancement of the existing program components, you will find several
additional new and helpful features in Version 6. Two additionally integrated search algorithms, known by our highly
acclaimed test winner O&O UnErase, you can now search for lost data even more effectively with O&O MediaRecovery.
The list of supported files was also enhanced so that more than 80 file types and file enhancements can be processed. The
advanced data rescue assistant guides you intuitively through the search and restoration process.
The system requirement of each operating system have to be fulfilled
Supported by 32 Bit/64 Bit
Windows® 2000 till Windows® Server 2008 R2 (all Editions)
O&O UnErase 6
These days the mistaken deletion of files is by far the most common cause of data loss. Windows tries to avoid this
problem with the recycle bin function – a sort of "clipboard" for deleted files. When the recycle bin is emptied these files
disappear leaving the user with the assumption that these files are now forever lost.
O&O UnErase can help you in this case. With the explorer-style file structure from O&O UnErase you can navigate
through your deleted files just as if they had never been deleted. With one click of the mouse you can restore single files
or entire folders.Whether it be those accidentally deleted text documents or those great photos from your last vacation,
O&O UnErase can restore all data stored on drives recognized and monitored by Windows*. With the detailed search
function you are able to tailor your search to a specific set of parameters that can increase the speed and precision of your
results.
30 MB free hard disk space for the installation and the subsequent use
Supported by 32-Bit/64-Bit
Windows® XP till Windows® Server 2008 R2 (all editions)*
安裝教學:
• Next open the OO Products Professional Editions x86.rar file by double clicking it. If you can't open it you need to get an
archiver which supports rar files such as Winrar.
• Click on extract and then run the setup to install
• Open the keygen chose the app that you whant to register and number of lincenses ( i allways chose unlimited license! )
put the desired user name and company and click on genarate serial copy and paste to the app that you are installing at
the moment.
• That's it! Done.
下載地址: (等待5秒再按下右上的Skip AD就可到下載頁)
Filepost載點
Wupload載點
Easy Share載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
JDownloader載點 || JDownloader後備載點
各空間等待時間為10至30分鐘,本身是該空間之Premium用戶則無以上問題
請勿使用續傳軟體抓取(如迅雷、Flashget等等),以免抓取失敗或抓到不完整檔案
[更新]WinRAR 4.0.1 Pro 32bit&64bit
4.0.1載點 || 4.0.1後備載點
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
1.僅供網路測試無任何販售行為及獲得任何利益!請於測試完後24小時以內將檔案刪除!
2.請支持正版!本檔案的提供純為試看用途,請勿作商業上之用途!!!!請於下載完後24小時以內將檔案刪除!!!
【軟體語言】:英文
【軟體類型】:系統維護
【檔案格式】:RAR
【檔案大小】:416MB
【壓縮密碼】:無
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
unable to start!
of the product.
32/64-bit support
System requirements
32/64-bit support
System requirements
32/64-bit support
32/64-bit support
O&O MediaRecovery 6
O&O UnErase 6
results.
安裝教學:
the moment.
• That's it! Done.
Filepost載點
Wupload載點
Easy Share載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
