主機板連續短音 換電源供應器也一樣
  • 主題發起人 主題發起人 jimmy7610
jimmy7610
我新組裝的電腦
Intel i5 3470
GA-B75M-D3H
剛組好開機就連續短音,
拆掉其他東西只留CPU和RAM
還是相同情形
換了電源供應器也是一樣
請問各位專業這是什麼情形
我新組裝的電腦
Intel i5 3470
GA-B75M-D3H
剛組好開機就連續短音,
拆掉其他東西只留CPU和RAM
還是相同情形
換了電源供應器也是一樣
請問各位專業這是什麼情形
連續短音各有分辨代碼,應該先分辨到底是幾個短音,再針對廠商對主機板短音所賦予的錯誤代碼來修正錯誤!!
記憶體 先 單插一條 開機
我新組裝的電腦
Intel i5 3470
GA-B75M-D3H
剛組好開機就連續短音,
拆掉其他東西只留CPU和RAM
還是相同情形
換了電源供應器也是一樣
請問各位專業這是什麼情形
它是連續短音之後(超過14次)
電源自動關閉再重開
一樣連續短音
這樣的loop
會不會是主機板上的8 pin接頭沒插上?
請翻主機板說明書,
上面有寫主機板的嗶音聲響數代表的原因………
技嘉這塊版子的BIOS是AMI EFI BIOS
警示音錯誤代碼:
1 short DRAM refresh failure The programmable interrupt timer or programmable interrupt controller has probably failed
2 short Memory parity error A memory parity error has occurred in the first 64K of RAM. The RAM IC is probably bad
3 short Base 64K memory failure A memory failure has occurred in the first 64K of RAM. The RAM IC is probably bad
4 short System timer failure The system clock/timer IC has failed or there is a memory error in the first bank of memory
5 short Processor error The system CPU has failed
6 short Gate A20 failure The keyboard controller IC has failed, which is not allowing Gate A20 to switch the processor to protected mode. Replace the keyboard controller
7 short Virtual mode processor exception error The CPU has generated an exception error because of a fault in the CPU or motherboard circuitry
8 short Display memory read/write error The system video adapter is missing or defective
9 short ROM checksum error The contents of the system BIOS ROM does not match the expected checksum value. The BIOS ROM is probably defective and should be replaced
10 short CMOS shutdown register read/write error The shutdown for the CMOS has failed
11 short Cache error The L2 cache is faulty
1 long, 2 short Failure in video system An error was encountered in the video BIOS ROM, or a horizontal retrace failure has been encountered
1 long, 3 short Memory test failure A fault has been detected in memory above 64KB
1 long, 8 short Display test failure The video adapter is either missing or defective
2 short POST Failure One of the hardware testa have failed
1 long POST has passed all tests
(來源:http://www.bioscentral.com/beepcodes/amibeep.htm
或是參照這個PDF(文件最底部):
http://www.ami.com/Support/download...kpoint_and_Beep_Code_List_PUB.pdf&FileID=1071
希望你能去算一下嗶嗶聲的聲數!!
看來........
你應該連bios畫面都看不到吧!!換一顆cpu測試,應該cpu哪裡沒裝好要不然就是壞了
