Womble EasyDVD v1.0.1.21
rapidmoon
代碼:
Description:
Womble EasyDVD v1.0.1.21 Portable | 12.55 MB
Womble EasyDVD is a DVD authoring tool that makes DVD authoring as simple, quick, and intuitive as possible. With a simple six step work-flow system, you will be able to create your own DVDs with just a couple of mouse clicks.EasyDVD combines Womble's smart rendering technology for MPEG-2 video and an extensive and flexible menu template support, it will appeal to users of all levels, from novice to seasoned professional.
Here are some key features of "Womble EasyDVD":
Intuitive User Interface:
? A simple six step work-flow will walk you through the whole DVD authoring process with ease and flexibility.
Multiple Movies Support:
? EasyDVD allows you to create a DVD with multiple titles, not just chapters: you can even combine multiple DVDs into a single DVD.
Time saver and video quality preserver:
? With our smart rendering technology in MPEG-2 video, you can quickly convert MPEG-2 video files into a DVD movie with minimal video re-encoding.
Full AC-3 audio encoder support:
? EasyDVD is capable of processing 5.1 channel sorround audio stream with fully licensed Dolby AC-3 encoder.
Creative Playback Controls:
? First Play lets you play an introductory video before the menu displays; End Action helps you tell different stories with the same video content.
Professtional-Looking Menu:
? EasyDVD provides you an extensible menu template support; it makes DVD menu authoring with ease and flexibility.
Real-Time Video Preview:
? Allows you to do a final check without outputting to the hard drive or DVD.
Burn with a built-in DVD burner:
? The built-in burner allows you to easily burn your exported DVD folder onto a DVD disc - no extra software required.
代碼:
Download Link: (Rapidshare)
http://rapidshare-mm.blogspot.com/2009/12/part1_3015.html
No Pass
