WinUtilities v9.41 Professional Edition
  • 主題發起人 主題發起人 viet80
viet80
Info:
WinUtilities Pro is an award winning collection of tools to optimize and speedup your system performance. this suite contains utilities to clean registry, temporary files on your disks, erase your application and internet browser history, cache and cookies. it also supports to defragment your disk drives and improve computer performance and stability. built-in Startup Cleaner allows you to control startup programs that load automatically with windows, find duplicate files, fix broken shortcuts and uninstall unneeded software. other features include secure file deletion, recycle bin shredding, system maintenance tasks scheduling and undelete deleted files.
Features:
• Defragment your disks and improve computer performance and stability
• Recovers deleted files on NTFS and FAT volumes.
• Cleans disks from information that clogs your system and reduces the performance of your computer.
• Scans the windows registry and finds incorrect or obsolete information in the Windows Registry.
• Helps you to easily manage program execution at windows startup.
• Erases all traces of activity on your computer, save spaces and protect your privacy.
• Splits any type of file into smaller pieces and rejoin them to the original file.
• Erases files and make sure that no data thief can get his hands on your sensitive data.
• Protects any Windows executable file with a secure password.
• Optimizes the Memory Management of Windows. No special configuration is needed, Memory Optimizer will auto configure itself.
• Helps you to free disk space by finding and removing duplicate files from your system.
• Provides you with an easy way to address the invalid shortcuts and reports back to you so that you can remove it from your system.
• Allows you to check your system’s performance and manage the running processes.
• Manages the programs installed on your system and uninstall unneeded software.
• Shows you the detailed information for your computer hardware and software
• Back up and restore the Windows Registry.
• Searchs the Windows Registry by a specific wildcard. then you can delete or export them.
• Manages the BHOs that are currently installed.
• Schedules your computer for log off, stand by, hibernate, or shutdown at a specific time.
• Provides you an easy way to launch the utilities build in Windows.
• Organizes and manage your Windows Settings
• Configures the cleaning tasks that takem place automatically.
Download Link:
代碼:
Hotfile
http://rapidshare-8.blogspot.com/2010/03/part1_4479.html
No Pass
Rapidshare
http://rapidshare-8.blogspot.com/2010/03/part1_8294.html
No Pass
