SharpLeech 2.0.0 ALPHA -auto forum poster
Info:
Things you should know:
Async leeching is automatically enabled when the Pause value in your options is set to 0. By setting it to 1 or higher the program will switch to the old sync leeching method. A fast site (both leech and post) and a 5Mbit+ connection are highly recommended for async posting. On slow sites/connections async posting might actually drown your speed instead of improving it.
Changes Since v2.0.0 Pre-ALPHA:
* Fixed a crash that would occur on some PC's when a window is opened for the 2nd time.
* Fixed a crash that would occur on some PC's when clicking on the login button.
* Fixed a crash or freeze that would occur when the Start Leeching button was clicked.
* Fixed the program not logging the ChatBox content when the option is enabled.
* Fixed a typo. I'm sure there are more typos left in the GUI so let me know if you find one!
* Fixed problems with IPB 3 quote tags.
* Added error logging layer.
* Added asynchronous leeching (300%+ speed boost on 5Mbit+ connections and fast sites).
* Removed all F# code and ported it to the C# DLL. The F# runtime is no longer required to be installed.
* Improved duplicate topic posting prevention - It will now check the hash before actually reading the topic (speed improvement).
* Improved Keep-Alive requests.
* Increased HTTP connection limit (2 -> 12).
* Changed the default timeout value from 100.000 to 30.000 ms.
* Changed the default Regex settings (they are now enabled by default).
* Changed the default ChatBox nickname. The program will now set your Windows username as default value.
* Changed the window background color for the non-Aero interface.
Info:
代碼:
Install .NET 4.0 RC before running
http://download.microsoft.com/download/0/1/1/011F8F7B-18F7-4AFD-A0C9-BD5AEDEF1DBB/dotNetFx40_Full_x86_x64.exe
代碼:
Download Link:
http://hotfile-1.blogspot.com/2010/04/sharpleech.html
No Pass
