S s3rv3r 普通會員 已加入 11/30/08 訊息 1 互動分數 0 點數 0 年齡 40 12/8/08 #1 This motherboard has anything similar a LOAD LINE CALIBRATION ? If Yes, what the option name ? Thanks.
NYboy 完美世界... 懷念... 已加入 2/9/09 訊息 770 互動分數 0 點數 0 4/6/09 #2 it's used for your cpu voltage keep static... :)
狂少 Bulletproof Themer 已加入 9/18/03 訊息 14,396 互動分數 2 點數 0 4/6/09 #3 s3rv3r 說: This motherboard has anything similar a LOAD LINE CALIBRATION ? If Yes, what the option name ? Thanks. 按一下展開…… loadline calibration is about the same as Vdroop function which you can see from DFI x58 board. with Vdroop control , it's about 0.02v offset less than what you set the vcore under bios. 樓上的勿會說不要亂誤導..啥是static?..;oq;
