【更新】Winamp 5.3 Full
Ethan.CPA
台北
簡介:
一個老牌的音樂撥放器支援許多格式 如MP3、MP2、MOD、S3M、MTM、ULT、XM、IT、669、CD-Audio、Line-In、WAV、VOC、OGG 等 多種影音格式,可以自訂面板,支援增強音頻視覺和音頻效果的外掛!
Change Log:
- New: Unicode filename and title support
- New: M3U8 (Unicode) playlist support
- New: optional 24bit playback for many codecs (turn it on in Preferences->Playback)
- New: Replaygain support for MP3, AAC, Vorbis, M4A and WMA
- New: added ml views & playlists to Play-> submenu of right click popup menu
- New: added interface/x-winamp3-skin mimetype for WAL skins
- New: [ml_dash] Personalized content portal
- New: [ml_disc] optional replaygain scanning after rip (turn it on in cd ripping prefs)
- New: [ml_pmp] Transcoding. Converts incompatible files on-the-fly for your portable device.
- New: [ml_pmp] Playback now works for playsForSure and Creative NJB devices
- New: [ml_pmp] "Copy to Library" - transfer songs from any device to your local library (uses CD rip settings)
- New: [ml_pmp] Video sync support for portables
- New: [ml_rg] replaygain scanner (access via Send To menu)
- New: [pmp_ipod] gapless playback support on newer models
- New: [pmp_usb] USB drive support. Now all those thumbdrive MP3 players can work with Winamp.
- Improved: fullscreen video seekbar
- Improved: ATF updates
- Improved: DC filter on spectral visualization, to remove bass bias
- Improved: preference cleanups
- Improved: faster PLS writing
- Improved: 24bit EQ support
- Improved: "Close Winamp" option after installation (after clicking 'Send')
- Improved: [enc_aacplus] Improved AAC and aacPlus encoding!
- Improved: [enc_aacplus] saves itunes/ipod-compatible gapless information
- Improved: [enc_lame] added preset medium and fast medium
- Improved: [enc_wma] VBR and lossless modes
- Improved: [gen_ff] better sample rate display
- Improved: [in_cdda] faster ripping speeds through improved buffering and multithreading
- Improved: [in_dshow] AVI metadata reading
- Improved: [in_dshow] better WAV support
- Improved: [in_mp3] 24bit MP3 playback, 64bit internal precision
- Improved: [in_mp3] streaming id3v2 support
- Improved: [in_mp3] replaygain support for MP3 playback
- Improved: [in_mp3/in_mp4] 24bit AAC playback
- Improved: [in_mp3/in_mp4] itunes-compatible gapless playback
- Improved: [in_mp3/in_mp4] mp3-in-mp4 container support
- Improved: [in_mp4] FAAC-compatible (mostly) gapless playback
- Improved: [in_wave] better outputs bits-per-sample choosing
- Improved: [ml_playlists] added missing entries from pledit context menus
- Improved: [ml_playlists] option to not show playlists in send-to menu
- Improved: [ml_pmp] Only relevant columns shown in song views
- Improved: [ml_pmp] "Getting Metadata" now much faster
- Improved: [ml_pmp] devices can now be renamed
- Improved: [ml_pmp] added progress to portables tree item (no more switching views)
- Improved: [ml_pmp] metadata guessing based on filename
- Improved: [ml_pmp] improved GUI performance
- Improved: [pmp_ipod] support for iTunesLock
- Fixed: Burning files that require resampling
- Fixed: multiple copies of Winamp when opening too many files/folders from explorer
- Fixed: freeze when exiting Winamp while minimized
- Fixed: Delay/hang when loading dead stream url's
- Fixed: crash when directdraw fails to create primary surface
- Fixed: 4x burn speed limit with Pro
- Fixed: registry handling when disassociating filetypes
- Fixed: better detection of video input plugins
- Fixed: [dsp_sps] 24 bit fix
- Fixed: [enc_aacplus] more compatible HE AAC MP4 file creation
- Fixed: [enc_lame] broken vbr presets
- Fixed: [enc_lame] 24bit input support
- Fixed: [enc_lame] bitrate lower bound on alt-presets
- Fixed: [in_cdda] CDDB lookups clearing the ENTIRE playlist cache
- Fixed: [gen_ff] layerfx not being redrawn on colortheme change
- Fixed: [gen_ff] gradient drawing glitch and crash
- Fixed: [gen_ff] custom color themes bug
- Fixed: [gen_jumpex] hang when suspending or hibernating
- Fixed: [gen_ml] tree icon fixup (divide by zero crash in ICM32.dll)
- Fixed: [in_cdda] cutoff of last few sectors
- Fixed: [in_dshow] crash when using DSP/EQ on anything bigger than 16bit stereo
- Fixed: [in_dshow] seek to key frame
- Fixed: [in_midi] truncated playback of some MIDI files
- Fixed: [in_mod] title display bug for module streams with no title
- Fixed: [in_mp3] crash when editing ID3 tags
- Fixed: [in_mp3] ID3v2 and ID3v1 Comment & Genre tags shared
- Fixed: [in_mp3] Inaccurate Time Remaining display for AAC files
- Fixed: [in_mp3] do Viz after DSP
- Fixed: [in_mp3] Icecast stream title UTF-8 support
- Fixed: [in_mp4] detection of HE AAC in file info box (Alt+3)
- Fixed: [in_wm] DRM Video playback on certain hardware
- Fixed: [in_wm] freezeup when seeking a paused wma
- Fixed: [in_wm] Hang with dead WMV link in pledit in Repeat mode
- Fixed: [in_wm] freeze when stopping streams that have rebuffered
- Fixed: [in_wm] small memory leak on each track play
- Fixed: [in_wm] Windows Media Screen Codec not playing properly
- Fixed: [ml_disc] CD ripping / playlist generation bug
- Fixed: [ml_disc] CD Ripping view showing up when clicking on other ml views
- Fixed: [ml_history] Ctrl+H shortcut
- Fixed: [ml_local] fixed crash when trying to create a new view before mldb has loaded
- Fixed: [ml_local] background scan crash when media library DB isn't loaded
- Fixed: [ml_local] scheduled background scan always starting at startup
- Fixed: [ml_online] Online Media bugfix (don't try to play NULL streams)
- Fixed: [ml_playlists] losing stream titles
- Fixed: [ml_playlists] sort by title
- Fixed: [ml_playlists] Send To from local media to ml playlist replaces instead of enqueues
- Fixed: [ml_playlists] Enqueue as default broken in left pane
- Fixed: [ml_playlists] Playlist title > rt-click > New Playlist = broken
- Fixed: [ml_playlists] tracklength bug
- Fixed: [ml_playlists] playlist paths issue
- Fixed: [ml_pmp] Transfers stalling after encountering a dupe
- Fixed: [out_ds] volume not hitting 0dB when using log or hybrid volume control
- Fixed: [pmp_ipod] Artist list on iPod not sorting "The" correctly
- Updated: Coding Technology aacPlus Decoder 8.0.0
- Updated: [gen_ff] Freetype 2.2.1
- Updated: [gen_ff] libpng 1.2.12
- Updated: [gen_jumpex] Jump-to-File 0.97.7
- Updated: [in_wave] libsndfile 1.0.16
- Updated: [libmp4v2] MPEG4IP mp4v2 1.5
- Updated: [enc_lame] LAME 3.97b3
- Updated: Sonic Engine 3.2.40.500
Download
Web
Winamp這老骨頭竟然還在呀......
有下有回!
請問D大和K大 你們分享的有中文化嗎?
謝謝你們喔^^..
推推推
一直以來都用這軟體
感謝大大
