Easy RM RMVB to DVD Burner 1.6.29_輕鬆轉換燒錄 RM 影片_免安裝
  • 主題發起人 主題發起人 le2712
le2712
【軟體名稱】:Easy RM RMVB to DVD Burner 1.6.29_免安裝
【軟體語言】:繁中
【軟體分類】:燒錄程式
【軟體格式】:RAR
【軟體性質】:共享
【檔案大小】:4.90 MB
【放置空間】:RapidShare/depositfiles
【解壓密碼】:no
【軟體介紹】:
它可以幫助你轉換RM等影片格式到標准的DVD格式,並集結燒錄成 DVD影片。它支援市面上大部分流通的幾種影片格式,例如 Divx、Xvid、AVI和其它格式,它也可以產生DVD映像文件,儲存到硬碟,或是從硬碟直接把DVD映像文件燒錄到DVD光碟上。支援NTSC和 PAL兩種電視制式,也支援4:3和16:9顯示畫面。
Key Features of Easy RM RMVB to DVD Burner
# Creates DVD from RM RMVB files and burn to blank DVD disc
# Generate DVD image and save to hard disk
# Burn hard disk DVD image to blank DVD disc
# Super fast conversion speed provided as it full supports Intel Pentium D Dual-Core Processor and AMD Athlon? 64 X 2 Dual-Core Processor which ensures full use of your CPU
# Merge up to 3 hours of multiple movies or episodic files to one DVD
# Multithreading and batch conversion are supported and the more files you convert the faster Easy RM RMVB to DVD Burner works than other DVD creators
# So easy to use that only ONE click is enough to burn a DVD after you loaded the video files
# Supports device types include DVD-R/ DVD+R/ DVD-RW/ DVD+RW
# Support NTSC and PAL
# Support 4:3 and 16:9 aspect ratio
# Add letterbox to keep the original aspect ratio
# All encoders/codec are built-in and any supported conversion can be done once you downloading the software
# Make excellent output quality
# Neat User Interface,very easy to use,without any complicated parameter settings
# No ASPI drivers needed
# Lifetime FREE Technical Support and FREE upgrade
OS: Windows 98//ME/NT/2000/2003/XP/VISTA
Homepage - http://www.divxtodvd.net/dvd-creator.htm
確保下載的軟體能正常使用,請使用
WinRAR 3.90 Final 版本解壓
感謝分享感謝分享感謝分享
