Driver Cure 1.5
Info:
Is your computer plagued by out-of-date Windows® XP, Vista®, and Windows® 7 drivers? Even if you have had just one driver problem, you know how frustrating it is to search online.
You never know which site to trust. You could harm your computer with a faulty driver or malware. For all the driver problems that ail your computer, ParetoLogic DriverCure is just what the doctor ordered.
ParetoLogic DriverCure will quickly and deeply scan your computer to let you know which drivers are out-of-date. Using clear prompts, ParetoLogic DriverCure will guide you through the installation of the drivers you need. Having the right driver versions means increased speed, performance, stability and new features. Many drivers are updated several times a year. ParetoLogic DriverCure makes sure that you have the latest versions. You will receive an email notifying you of a new driver and helping you update. This ensures your PC is always working at its best.
Key features:
Sets system restore point so that you revert
back to your old drivers
Improved performance and stability thanks to having the latest Windows XP, Vista, and Windows 7 drivers for your printer, scanner, sound card, digital camera, graphics card, mouse, display and other devices
Email notification of when new drivers for your computer are available. You do not have to worry about the hassle of checking for new drivers
Removes worries of lost disks. With ParetoLogic DriverCure, you can easily find the right driver without having the original disk
Eliminates your risk of downloading a faulty driver or malware. The wrong driver or malicious code could cripple your PC
Monitoring of a growing list of more than 4,000 software applications and over 3,000 hardware vendors
A small footprint. ParetoLogic DriverCure takes up minimal system resources, ensuring that you have all the power you need for other computing pursuits
Info:
Key features:
代碼:
Download Link: (Rapidshare)
http://rapidshare-8.blogspot.com/2010/03/part1_5808.html
No Pass
